Old 05-28-2008, 08:03 AM   #1
tgzzzz's Avatar
tgzzzz is on a distinguished road
What cause damage to my 350 Chev?
Any theories on what caused this damage to my 350 Chev in motorhome? 2 plug gaps were squeezed shut. Truck still started and ran OK although didn't produce much power.
what-cause-damage-to-my-350-chev-86-chev-002.jpg  what-cause-damage-to-my-350-chev-86-chev-001.jpg
tgzzzz is offline   Reply With Quote
Old 05-28-2008, 08:07 AM   #2
03chevy's Avatar
did you have any head work done? or know of any head work been done? if so then they shaved the head to far and the piston hit the plug
Old 05-28-2008, 10:38 AM   #3
Was the motor rebuilt with hyper pistons?
Otherwise something got through the motor.
Joe
89 K2500 Chevy, Wee-Oh-five
285K miles, completly rebuilt
needs a motor, bad
152 ci, dana everything else
Old 05-28-2008, 10:49 AM   #4
Foriegn object in the engine.
Thise pistons are hammered, and much of the damage looks to be from something inside of the cylinder.
How does the combustion chamber look?
I might have first assumed that perhaps the timing chain was bad, and the piston made contact with the plugs, but the location where the pistons are broken do not support this theory.
Smaller pits are not visible, so detonation may not have been an issue, and the sharp cuts in the piston would indicate a foreign object.
Tough to imagine anything getting past the air filter, but perhaps something from the carb failed. Have you inspected the carb real well?
Maybe something from here fell into the intake, and caused you trouble????
Just a guess.
Old 05-28-2008, 12:54 PM   #5
I would have to Agree with 75. Looks like something foreign was bouncing around in there.
Old 05-28-2008, 01:42 PM   #6
Sure there was.... Piston pieces. If I am not mistaken that is the top ring you are looking at on the top edge. Either it is leaned out or you have had some seroius detonation problems.
Old 05-28-2008, 02:21 PM   #7
Good eye!
Looking back at it all 3 pistons in the picture are the same. missing chunks out of the top part of the piston.
Old 05-28-2008, 04:13 PM   #8
tgzzzz's Avatar
Good eye indeed. That is the top ring visible. This was a 10K Goodwrench remanned engine.
So what happened? I was driving along and felt a loss of power. Managed another 100 miles along I-95 with less and less power. 3 pistons on the pass side are damaged and I don't have the driver's side head off yet. I've been drinking and crying in my beer so far but engine will be out next week.
When this happened, I noticed way too much oil vapor being fed into carb (oil running out of air cleaner) and PVC valve hose (blown?) out of valve cover, and loose air pump belt.
My theory is air pump quit sucking air out of oil pan, pressure built up to force oil vapor out of crankcase, blowing PVC valve out of place, then ...... what?????
How can I avoid this in the future?
Old 05-28-2008, 10:33 PM   #9
Jessie is on a distinguished road
It appears that the groove on the piston let the ring come out and a piece broke off and got on top. Is the block cracked now? If the engine is rebuilt maybe wrong size pistons used for the bore. Or could be a piece of the piston on the side is gone. About the oil vapor I'd say that was compression going by the piston and back thru the oil pan.
Jessie is offline   Reply With Quote
Old 05-28-2008, 11:28 PM   #10
Sneakysportsman's Avatar
Sneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to behold
Correct me if I am wrong but those pistons look like they weren't clearenced right to the Cyl walls resulting in a Squeeze at the top of the stroke. Or the pistons were getting out of line during the down stroke- over-bore with under sized pistons. rip that head gasket off and post another pic so we can see piston at the top of the stroke.
Sneakysportsman is offline   Reply With Quote
I'm Looking for advice, 73-87 Chev box floor in 67-72 chev truck? dhashigu Chevy Truck Forum 2 07-06-2007 08:05 PM
Body Damage Questions Ryan2000ak Chevy Truck Forum 4 03-07-2007 10:30 PM
Truck strike will damage business, says port official (Canada.com) trucknews Truck News (headlines) 0 06-27-2005 05:30 AM
Rainfall causes damage to new park trail (The Ohio University Post) trucknews Truck News (headlines) 0 04-26-2005 09:30 AM
Damage, power outages plague Tift County (WALB News 10) trucknews Truck News (headlines) 0 09-06-2004 05:30 PM
