| I have a 99 silverado and am thinking of putting an add a leaf under neath the back to stop sagging. I'm wondering if it will stiffen my ride too much. any suggestions? which brand to go with? |
| Welcome to the club. I was thinking of adding a kit to my truck as well. |
| Full Member Join Date: Feb 2007
| i bought an add a leaf kit from ebay for $50 and i also bought a set of rear shocks with those coil springs on them to increase load capacity. my truck is about 3 inches higher in the rear and supposely the add a leaf adds an extra 1500lbs and the shocks level out 1500lbs also. have yet to throw some serious weight in the back so far, but planning on putting a ton back there soon. |
| oh and the ride feels almost the same on my 93 k1500 5.7 |
| just make sure ur axel will support it
__________________ //B-rad |
| well i have spare springs all i did was took a leaf out of them and added it the ones on my truck. i had to get longer u bolts other than that it works great a little stiffer but better can haul more wit out saggin to much. but my buddy got a add a leaf from oh one othe lift company's for his jeep and the spring broke so he was out like 125. |
| HUH??? Yes ther ride will be stiffer. as mentioned you may need longer u bolts.
| mine is alot stiffer but with 1500# in the back of a 1/2 ton, she dont sag one bit. rides awesome with alot of weight. just cant afford to carry that much junk around. |
| I ment to say make sure ur rearend will support that weight
| Isn't there some type of kit that you add a leaf on the top part of your factory leafs with some type of u-bolts so when you add weight it will help out am I wrong I couldn't find a picture I wouldn't want to lift my truck up I like my ride height? Pictures anyone??????? |
| update on squeaking leaf springs | classicZ71 | GMC Truck Forum | 9 | 05-01-2008 06:18 AM |
| Annoying leaf springs | classicZ71 | GMC Truck Forum | 2 | 03-24-2008 05:35 AM |
| 94 ranger rear leaf springs | lmm3466 | Ford Truck Forum | 0 | 07-13-2006 06:52 PM |
| Couple in 48/13 truck death had history of fights (Leaf-Chronicle) | trucknews | Truck News (headlines) | 0 | 01-02-2005 07:30 AM |
| Torsion bars and add a leaf 2 in front 2 1/2 rear? | 98Z71 | Chevy Truck Forum | 0 | 11-13-2004 11:46 PM |
