| 1988 chev truck overdrive shifting problem Just started having trouble with auto trans shifting into overdrive sometime takes several miles. What makes the trans shift into overdrive and is there anything i can change. Has 180,000.00 miles 1988 ck |
| Senior Member Join Date: Mar 2008 Location: levittown pa
| try tighneing the kickdown cable it may have stretched over the years and now is out of adjustment, |
| Change fluid filter and gasket. Check the TV cable mentioned, But i dont think that has much to do with this particular problem, but its cheap to check in case.
| 1988 silverado speedo problem | joecuccovia | Chevy Truck Forum | 6 | 03-11-2008 05:22 PM |
| shifting problem | allthrotle | Chevy Truck Forum | 5 | 01-23-2008 12:34 PM |
| 95 dodge shifting and overdrive problem | bsolis | Dodge Truck Forum | 0 | 03-24-2007 04:01 PM |
| Automatic tranny problem,trouble shifting | DEP | Dodge Truck Forum | 3 | 03-01-2007 01:19 PM |
| 99 Silverado shifting problem | 04HEMIRAM | Chevy Truck Forum | 8 | 02-15-2007 08:09 AM |
