| k2500 front brakes Does any one have some advise on replacing the front brakes on my 98 k2500? |
| as far as what? do you know how to replace brakepads/calipers/rotors? what are you trying to replace?
__________________ "She's gonna Freak when she see's my wheels" 85' Chevy C-10 Longbox (Rat) TBI 5.7 Liter/THM350 90' Chevy Suburban 4x4 TBI 350 Cu.In./700R4 http://www.truckforum.org/forums/truck-pictures-176.htm |
| I'm trying to replace the pad's and rotor's. I'm having trouble removing the front hub so I can get the rotor off. I've already taken the four bolts off and tried to use a puller. The puller just pushed the fron axel out of the hub. Also there is a wire that I believe is for the abs how does that come off? any help would be greaty appriciated |
| unhook abs harness from frame/a-arm. remove 36mm axle nut, put nut back on and hit/loosen joint in bearing remove brake caliper remove 4 hub retaining bolts spray lots of lube in the 4 holes reinstall the 4 hub retaining bolts about 1/4 the way in either use air hammer or manual hammer and alternate hitting the bolts, be carefull not to damage the bolts too badly(use grinder to clean up after) spray lube liberally. remove the studs to replace rotor. |
| Did you take the caliper off before you tried to remove the disc?
| 90 K2500 won't start hot | alaskaworktruck | Chevy Truck Forum | 4 | 06-01-2008 07:00 PM |
| 01 K2500 drl always on | Digga | Chevy Truck Forum | 5 | 02-26-2008 08:07 PM |
| Front receiver hitch for a 1986 K2500 | chengny | GMC Truck Forum | 8 | 01-10-2008 01:21 PM |
| 4x4 Low in 1989 K2500 | Captain Morgan | Chevy Truck Forum | 3 | 01-05-2008 07:44 PM |
| Changing Front Brakes to Disc | Austinr98 | Chevy Truck Forum | 1 | 07-15-2007 03:39 PM |
