Old 06-01-2008, 03:01 PM   #1
1-tonsrule is on a distinguished road
1999 6.5 turbo diesel problems
i recently bought a 99' 3500HD with a throttle by wire 6.5 diesel and standard 5 speed tranny. the problem is it will quit running at random. and its like its losing electrical power when it does. the pickup pumps been replaced, as well as the pedal assembly, and almost everything but the gadge cluster. any ideas?
1-tonsrule is offline   Reply With Quote
Old 06-01-2008, 08:03 PM   #2
Moderator
If that thing is drive by wire it should have a cam shaft position sensor and or crank position sensor. I would check to see if it has any codes and also try to find a shop that wont charge you an arm or a leg to hook it up to a real time scanner and check those 2 sensors.
Old 06-02-2008, 08:13 AM   #3
stumpuller454's Avatar
stumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud of
my dad had a 98 were there was some wiring loose under the fuse block, wouldn`t start sometimes, is easy to check, unbolt fuseblock and have a look underneath, see if anything is loose, use a testlight too, just an idea!
1994 K2500 Silverado, 6.5 Turbo Diesel - Injection Pump Problems? catrel Chevy Truck Forum 2 05-23-2008 04:19 PM
2005 F250 turbo diesel ignition on with no key brooklyn Ford Truck Forum 4 10-23-2007 09:16 PM
1999 F-250 7.3 Turbo Diesel engine oil, filter, etc info. Kawboy Ford Truck Forum 2 12-26-2006 09:33 AM
94 Chevy Turbo Diesel For sale Felix Harsh Truck Classifieds 5 05-23-2006 10:58 AM
1997 Chevy Silverado 2500 Turbo Diesel Big Diesel Chevy Truck Forum 2 11-10-2005 11:25 AM
