Old 06-04-2008, 04:29 PM   #1
cplnorton is on a distinguished road
AC compressor not engaging
I'm figuring it's the compressor, but I wanted to get your guys opinion.
I have a 1992 Chevy 1500 with a 350.
The refigerant was a little low so I started to charge it. After I put some in, I jumped the switch on the side of the condesor. The compressor kicked on fine for about a couple seconds and then shut off. I then noticed it blew the AC/Heater fuse.
I replaced it and jumped it again. The compressor kicked on and then off. I checked the fuse, but it was still fine.
I then just plugged the plug back into the switch and I started pumping more Refigerant into the compressor and it started to short cycle for about 30 seconds and then it just quit.
Now nothing I do with get it to go again. I don't know if it just seized up. I've never been really good with AC, but it would have to be the compressor or the high/low switch wouldn't it?
Thanks!
Steve
cplnorton is offline   Reply With Quote
Old 06-05-2008, 05:46 AM   #2
With engine off try rotating the center bit of the compressor pulley by hand. You should be able to turn it quite easily. As you turn it there should be a slight resistance against compression. If it turns OK then your compressor is not seized. I would then think you possibly have a defective clutch on the pulley. You should be able to check the clutch by unplugging the wires going to it and putting a meter across the wires. There should not be an open circuit or a dead short. There should be a resistance reading. Hope this helps.
Old 06-05-2008, 06:02 AM   #3
03chevy's Avatar
if everything checks out with what Case says then what is the reading on how much you have in it??
A/C compressor used for air tools??????? Chevy_Finatic79 Chevy Truck Forum 2 05-11-2008 05:02 PM
AC Compressor problem gerryl98 Chevy Truck Forum 13 12-15-2007 08:18 PM
AC compressor noisy jktuck Chevy Truck Forum 4 05-14-2007 02:48 PM
A/C Compressor Installation help!!!??? 4x4s1088 Chevy Truck Forum 2 08-08-2006 04:21 PM
replacing AC Compressor teampenner Chevy Truck Forum 16 07-19-2006 10:13 AM
