Old 06-06-2008, 10:19 PM   #1
athomas01 is on a distinguished road
4x4 steering vibration problem
I have an 1998 chev 4x4 with a steering vibration problem which shows up more noticably when pulling a load. I noticed this problem after pulling some
tree stumps in the backyard. I think this has caused the problem. Maybe something is bent out of shape.
Under normal driving conditions there is no probems. I've just put on 4 new tires and had them balanced. that should take the tires out of the picture.
I also had an front end alignment done, and that doesn't help either.
Any suggestions?
athomas01 is offline   Reply With Quote
Old 06-06-2008, 10:43 PM   #2
Welcome to the site;
This sounds like a balance problem, and since you are confident that the tires are not the problem, (alignment is alright, though this will not cause a vibration) then something else that rotates has got to have some trouble, and the first thing that comes to mind is the driveshaft.
Verify that the u-joints are still good, and all of the associated components.
Once you eliminate u-joints, then you can look to see if the shaft itself has any damage. Dents, or twists can, and will cause terrible vibrations.
Old 06-07-2008, 08:06 AM   #3
Flopeyeman's Avatar
Flopeyeman is on a distinguished road
Might want to check your engine mounts
Flopeyeman is offline   Reply With Quote
Old 06-07-2008, 05:00 PM   #4
I will check the u-joints and get back to you. thanks to 75K30
Old 06-07-2008, 10:06 PM   #5
Sneakysportsman's Avatar
Sneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to behold
In 1996 gm Claims to have introduced Speed sensitive power steering, I don't know how this works nor have I ever seen this.
Sneakysportsman is offline   Reply With Quote
Old 06-08-2008, 05:40 AM   #6
second vote for u-joints.
99 Silverado Steering Column Vibration rockitman Chevy Truck Forum 7 06-11-2008 07:44 PM
Steering Problem mxer201 GMC Truck Forum 7 11-19-2007 08:08 AM
steering problem fanelle Chevy Truck Forum 8 01-27-2007 02:48 PM
2005 4WD Vibration Problem not_a_mechanic Chevy Truck Forum 6 10-11-2006 07:08 PM
Steering column vibration in 92 4x4 mochester Toyota Truck Forum 3 05-20-2006 11:27 PM
