Old 06-09-2008, 11:49 AM   #1
azzkier is on a distinguished road
Early 80's small block Water pump problem
I have a early 80's small block 350 that keeps blowing water pump gaskets. If you're looking at the motor, it's the left side gasket , keeps leaking after about 1 hr of run time. I've tried all diffrent kinds of gaskets, water pumps. any ideas?
azzkier is offline   Reply With Quote
Old 06-09-2008, 11:59 AM   #2
Wlecome to the site;
How flat is the sealing surface on the block? Is there any gouges or problems with the matting surface?
What types of sealers are you using (if any) and are you using sealers correctly? Many times RTV type sealers will squeeze out if not allowed to set up properly before the fasteners are tightened down.
Old 06-09-2008, 12:07 PM   #3
Thanks,
Surface is perfect, i've tried sealers and gaskets. It's like there it too much pressure on it, just eats the gaskets away. I put a diffrent set of heads on it, ever since i did, it's done this.
Old 06-09-2008, 12:31 PM   #4
Chevy_Finatic79's Avatar
what kind of heads did you install? did you put reverse water-flow heads on it? does the thermostat open
85' Chevy C-10 Longbox (Rat)
TBI 327 Cu.In./THM350
90' Chevy Suburban 4x4
TBI 350 Cu.In./700R4
Old 06-09-2008, 12:42 PM   #5
Heads are just regular Gm iron heads, 202 valves. No stat, (guts been removed). Motor is in a mud truck, running 475-500hp on dyno. Im not up on all the older gm stuff, i only mess with the LS stuff. I didnt know if there was a cross over or something for the heads, steam building up, ect, ect.
Old 06-09-2008, 01:19 PM   #6
The heads should have little to do with the water pump itself. I do however have another theory though. Is it possible that one or more of the bolts is just barely too long, and the shoulder is bottoming out and not giving you proper torque?
Improper claming force could cause this issue.
with only 4 bolts holding the pump on, this should be a pretty easy fix. This one has me scratching my head a little.
Old 06-09-2008, 01:29 PM   #7
Very well could be that. I just assumed they were not blind holes though. I'll check it.
Old 06-09-2008, 01:37 PM   #8
Right on. I was just thinking that not all of the bolts are the same length, and if you have the long bolts in the wrong spot, it may bottom out on the shoulder, or maybe the bolt itself has a problem.
Good luck with that, sometimes those little things can drive you crazy.
Old 06-09-2008, 01:47 PM   #9
Ya...I was about the put the ls1 back in it! Hope that its just the bolt issue.
Bad water pump? TomW Chevy Truck Forum 11 05-13-2008 12:12 PM
HELP S10 4.3 installing water pump , cant get water pump fan off STRAYDOG Chevy Truck Forum 6 01-12-2008 12:26 PM
water pump jktuck GMC Truck Forum 10 06-23-2007 03:27 PM
Changing a 1989 chevy k1500 tbi to a 355 carburated small block .lots of info plez pscheers Chevy Truck Forum 3 05-21-2007 04:23 PM
How do you change a water pump chafuro786 Ford Truck Forum 2 03-07-2007 09:09 PM
