Old 06-19-2008, 02:43 PM   #1
darin00 is on a distinguished road
Need help with a 95 chevy
I have a 95 chevy i just change the fule pump and now when i try to take off it dies on me it idles just find it only happens when you try to take off and then its hard to start back up can anyone help me?
darin00 is offline   Reply With Quote
Old 06-19-2008, 02:47 PM   #2
Moderator
have you checked to make sure your filter has not gotten plugged up?? in park, can you rev the engine without it dying or does it do it only at takeoff??
Old 06-19-2008, 02:49 PM   #3
well i put a new filter on it too and when you rev it up it dies too.
Old 06-19-2008, 02:55 PM   #4
Moderator
check fuel pressure. might be a busted pump that cannot keep enough pressure up to keep the injectors working.
Old 06-19-2008, 05:25 PM   #5
ok what if the fuel pump is ok could it be something with the injectors.
Old 06-19-2008, 07:00 PM   #6
jman1973 is on a distinguished road
make sure the fuel filter is installed correctly
it only flows one way
jman1973 is offline   Reply With Quote
Old 06-20-2008, 11:10 AM   #7
well i check to fuel filter to see if was on right and it is on right i also check the fuel pump pressure and its ok now i'm looking at the throttle body and the T.P.S would any of those make it stall when put in gear?
Old 06-20-2008, 12:22 PM   #8
Moderator
a tps malfunction would throw a code as well as make it do crazy things in and out of gear. what kind of pressure do you have right now?? injector problem might be there but doubtful since it ran fine before. why did you end up changing the pump in the first place??
Old 06-20-2008, 02:33 PM   #9
z07
z07's Avatar
z07 is a glorious beacon of lightz07 is a glorious beacon of lightz07 is a glorious beacon of lightz07 is a glorious beacon of lightz07 is a glorious beacon of lightz07 is a glorious beacon of light
Brad's got the next step for sure. Find out what the fuel pressure is now. In troubleshooting fuel pressure problems, people often attach a gauge and duct tape it to the outside of the windshield so they can see it under various loads.
EDIT: Disregard the 35psi and 45psi numbers in the next line. Sneaky's post below explains why.
If the pressure is ok at idle (35psi or so) and doesn't increase with RPMs (45psi or so) then the little diaphram in the fuel pressure regulator is done.
Old 06-21-2008, 05:09 AM   #10
Sneakysportsman's Avatar
Sneakysportsman is just really niceSneakysportsman is just really niceSneakysportsman is just really niceSneakysportsman is just really niceSneakysportsman is just really nice
Fuel press on a 95 is only 12 psi max. It a TBI.
Sneakysportsman is offline   Reply With Quote
