| | #1 | |
| Brake Warning light Was seaching on forums and came across this thread. Brake Warning Light Problem I have same problem. This is where I am right now.I have done what crabtruck said shown below iand I have a 4 code showing. Quote:
| I should probably say what I have. 1990 Chevy k1500 all new brakes rotors, pads, drums, shoes and master cylinder. Whole system has new fluid and the light was on prior to doing brake job. Mark |
| Also should mention that I have reset the code and light goes out for only a few seconds than come back on when rechecking it is the 4 code. |
| Acording to my book code 4 is a grounded reset switch circuit. The reset switch is in the anti-lock brake combination valve. This should be below your master cylinder. Try unplugging the electrical connectors and cleaning them. |
| Thanks for the response. I just got back in, will give it a try in the morning. Right now it is pouring out, been having off and on thunderstorms around here all day. Mark
__________________ When in doubt Accelerate |
| Case 7230 thanks for the info, it was not the connections. It was the switch. I changed it out and now all is good. Thanks again. Mark
| Glad you got it fixed. |
| Mark D Welcome to the club that a good write up you found and posted that's 5 points for you. Be good! GMC |
| Brake Warning Light Problem | Jessie | Chevy Truck Forum | 36 | 08-14-2009 03:00 AM |
| problems w/ brake warning light?? | zr2chevy | Chevy Truck Forum | 6 | 05-09-2008 11:11 AM |
| Brake warning light goes on at 35 MPH | darisb | GMC Truck Forum | 25 | 04-02-2008 05:36 AM |
| parking/brake light on | pbouffard | Chevy Truck Forum | 5 | 06-19-2007 03:04 PM |
| brake light | smokensteve | Chevy Truck Forum | 3 | 05-12-2007 04:33 AM |
