Old 06-29-2008, 08:45 PM   #1
jquartucy is on a distinguished road
Please help with electrical problem!!
I have a 1993 Suburban. It was starting intermittently. Assumed it was the starter. Had it tested and it was fine. Then it started running rough. We parked it, and have had this problem ever since. It will not start. The headlights are stuck on. The right turn signal is stuck on. When you try to start it, the gages all max out and nothing. I have check every fuse and all the wires under the dash. I have pulled all the switches, including the headlight switch and the lights will not go off. I changed the ignition switch and same problem. Any ideas?
jquartucy is offline   Reply With Quote
Old 06-29-2008, 09:49 PM   #2
welcome to the forum.
not good with electrical, but i would trace your wires and look for a short.
i'd rather be hunting
Old 06-29-2008, 09:59 PM   #3
I have tried that...about 2 days worth of searching. I can't see any bad wires.
Old 06-29-2008, 10:08 PM   #4
heavychevy85's Avatar
heavychevy85 has a spectacular aura aboutheavychevy85 has a spectacular aura about
clean all ur conections check and clean all grounds try the relays if they short stuff can go bonkers its there just gota find it
heavychevy85 is offline   Reply With Quote
Old 06-29-2008, 10:10 PM   #5
By testing relays do you mean removing them? I tried this and no luck.
Old 06-29-2008, 11:44 PM   #6
I really don't know somebody will chime in just wait have your battery checked a bad one will fool you good.
Old 06-30-2008, 07:30 AM   #7
Chevy_Finatic79's Avatar
you need to do a spark test and a fuel test. we need to make sure you have spark and the injectors are dumping gas before you go on a wild bad wire goose chase.
things I'd suspect would be the distributor and it's components. Cap, wires, Ignition Module, Coil
85' Chevy C-10 Longbox (Rat)
TBI 327 Cu.In./THM350
90' Chevy Suburban 4x4
TBI 350 Cu.In./700R4
93 S-10 electrical problem lite39 Chevy Truck Forum 2 08-08-2008 07:05 AM
93 electrical problem lite39 Chevy Truck Forum 5 05-07-2008 08:02 PM
90' burban electrical problem Chevy_Finatic79 Chevy Truck Forum 11 04-18-2008 10:55 PM
95 s-10 electrical problem joshuapa Chevy Truck Forum 4 03-31-2008 07:27 PM
electrical problem hjsherrod Introductions 1 01-23-2007 02:46 PM
