Old 07-02-2008, 06:01 AM   #1 (permalink)
rdhack will become famous soon enough
Temp Gauge Calibration
1995 Chevy 5.7L k2500 4x4
My temperature gauge just can't be right. Truck has newly installed 180 degree thermostat and sending unit. The gauge reads just under 160 degrees. Is there any way to remedy this? A calibration method perhaps? Or do I need a new gauge?
Thanks
MY first truck was a FORD.......I've owned Chevy's ever since.
1995 K2500 4x4 5.7L Cheyenne
1991 T-10 Blazer 4.3L Tahoe Package
1998 Oldsmobile Bravada 4.3L Vortec Smart Drive
rdhack is offline   Reply With Quote
Old 07-02-2008, 06:03 AM   #2 (permalink)
03chevy's Avatar
03chevy has much to be proud of03chevy has much to be proud of03chevy has much to be proud of03chevy has much to be proud of03chevy has much to be proud of03chevy has much to be proud of03chevy has much to be proud of03chevy has much to be proud of
is that while you are driving or sitting still? driving that is fine put sitting still you need a new guage
Old 07-02-2008, 06:07 AM   #3 (permalink)
It is while driving
Old 07-02-2008, 06:09 AM   #4 (permalink)
03chevy's Avatar
that's fine because the air running through the radi. help keeping it cool. other than just the fan trying to keep it cool.
Old 07-02-2008, 08:00 AM   #5 (permalink)
Moderator
bradrhale is a splendid one to beholdbradrhale is a splendid one to beholdbradrhale is a splendid one to beholdbradrhale is a splendid one to beholdbradrhale is a splendid one to beholdbradrhale is a splendid one to beholdbradrhale is a splendid one to behold
keep in mind that the temp guage is not calibrated to accuracy. you can get in 5 different trucks and get different readings but all run the same temp. they are more or less a guide. if one day it is alot higher than it normally runs, that would be an indication of a problem.
Old 07-02-2008, 08:05 AM   #6 (permalink)
Chevy_Finatic79's Avatar
Chevy_Finatic79 is a name known to allChevy_Finatic79 is a name known to allChevy_Finatic79 is a name known to allChevy_Finatic79 is a name known to allChevy_Finatic79 is a name known to allChevy_Finatic79 is a name known to all
160 seems way to low for normal operation I have a 160 thermostat on my truck and in park @ just idle it reads around 180 to 190. anything over 205 degrees will break down oil life and vescosity in less than 30 days
85' Chevy C-10 Longbox (Rat)
TBI 5.7 Liter/THM350
90' Chevy Suburban 4x4
TBI 350 Cu.In./700R4
Old 07-21-2008, 03:54 AM   #7 (permalink)
97GMC1500 is on a distinguished road
Temp Guage fluctuating
I noticed while I was driving this morning that the temperature guage in my 97 GMC was bouncing from one line below 210 to one line above. It didn't matter if I was driving or sitting still. Any ideas?
97GMC1500 is offline   Reply With Quote
Old 07-21-2008, 06:50 AM   #8 (permalink)
Moderator
if it is bouncing around like that, it might be a faulty gauge. might also be your sensor. also check that you have good connections at your plugs
Old 07-22-2008, 06:40 AM   #9 (permalink)
leolkfrm is a splendid one to beholdleolkfrm is a splendid one to beholdleolkfrm is a splendid one to beholdleolkfrm is a splendid one to beholdleolkfrm is a splendid one to beholdleolkfrm is a splendid one to beholdleolkfrm is a splendid one to beholdleolkfrm is a splendid one to behold
an air bubble.. or low collant will also make the guage bounce. do you have an air bleeder on the housing with the sensor?
Old 07-22-2008, 09:14 AM   #10 (permalink)
fbhart@wk.net will become famous soon enoughfbhart@wk.net will become famous soon enough
question, why do you have a 160 degree thermostat?
i believe a 195 is std for this motor.
hook up a direct connect manual gauge to the motor, they are much more dependable.
Plus a stewart warner 270 degree gauge looks cools,
I use all manual gauges for coolant, oil and volts, do not trust electronic gauges.
fbhart@wk.net is offline   Reply With Quote
Fuel Gauge and Oil Pressure Gauge problems landonh GMC Truck Forum 12 04-23-2008 10:26 PM
Water Temp Gauge 1984heartbeat Chevy Truck Forum 7 09-27-2007 07:05 AM
Non-functioning temp gauge C30 Dooley Chevy Truck Forum 7 03-24-2007 07:31 PM
Temp gauge Help claytonfrnk Chevy Truck Forum 2 03-16-2007 06:20 AM
