Old 07-04-2008, 08:44 PM   #1
Faster4344 will become famous soon enough
truck misses when cold??
hay everyone I have got a proble with my 96 350. when i start it up and the motor is cold it almost sounds like it is missing and breaking up. Ill go down the road and there is almost a bucking situation in it. I thought bad gas but no matter where I get gas this seems to happen. It is also only when the motor is cold. not only when it is cold uptside just upon the first start up. It bucks or misses or has a lack of power when you really get on it within the first min or two. I really would think that it would throw a code but i can get one out of it. Any ideas. I have new plugs, wires, head gaskets too. I had a problem similar to this when i had my bad head gasket also. I am lost??
Faster4344 is offline   Reply With Quote
Old 07-05-2008, 10:28 AM   #2
heavychevy85's Avatar
heavychevy85 has a spectacular aura aboutheavychevy85 has a spectacular aura about
i had the same problem with my 95 jetta i sold when it was cold for like a min it would idle ruff and i never realy woriied about
heavychevy85 is offline   Reply With Quote
Old 07-07-2008, 06:46 AM   #3
Check the temp sensor with a scan tool and see if the voltage specs are at the low end
Last edited by leolkfrm; 07-08-2008 at 08:07 AM. Reason: should have wrote, temp sensor
Old 07-07-2008, 08:15 AM   #4
how would one do that. Is that something like advanced auto parts woould doo for free?? I have a superchips chip and that will read trouble codes but i have none to read.
Old 07-07-2008, 09:24 AM   #5
03chevy's Avatar
03chevy has a brilliant future03chevy has a brilliant future03chevy has a brilliant future03chevy has a brilliant future03chevy has a brilliant future03chevy has a brilliant future03chevy has a brilliant future03chevy has a brilliant future03chevy has a brilliant future03chevy has a brilliant future03chevy has a brilliant future
have you check these items yet?
1Inspect Idle Speed Control Actuator Damaged, loose, or faulty idle speed actuator
2Inspect Throttle Position Sensor Faulty throttle position sensor or throttle position sensor circuit.
3Inspect Wireset Damaged, worn, or deteriorating spark plug or coil wire(s).
4Inspect Idle Stop Solenoid Damaged, loose, or faulty idle stop solenoid
5Inspect Idle Air Control Valve Damaged, loose, or faulty idle air control valve
7Inspect Spark Plug Wire Loom - Performance Improperly adjusted or worn/malfunctioning carburetor.
8Inspect Air Filter Clogged or dirty air filter
9Inspect EGR Valve Clogged, dirty or improperly functioning or defective egr valve.
10Inspect Fuel Filter Clogged or dirty fuel filter
11Inspect Fuel Injector Plugged, dirty or poorly connected fuel injector.
12Inspect MAP Sensor Improperly connected or faulty m.a.p. sensor.
13Inspect PCV Valve Plugged or damaged pcv valve.
14Inspect Point Set Burned, worn or incorrectly set ignition points.
15Inspect Spark Plug Fouled, damaged or broken spark plug(s).
16Inspect Fuel Pump Improperly functioning fuel pump or circuits.
Old 07-08-2008, 08:11 AM   #6
You need a good scan tool which gives actual readings, not just codes! in the long run the cost of the reading may be cheaper then throwing parts at it.
Also have you tried the original set up to eliminate the posability it's the superchip?
Engine Misses after warming up rdhack Chevy Truck Forum 12 07-11-2008 05:20 AM
Help runs good cold misses bad hot 90 5.0efi tonyvt Chevy Truck Forum 10 03-28-2008 12:47 PM
cold Ram tigman250 Dodge Truck Forum 6 01-31-2007 06:21 PM
Family Spends Cold Night In Snowbound Truck (KOIN News 6) trucknews Truck News (headlines) 0 01-04-2005 06:30 PM
Motor Sports Notebook: Jefferson misses cut for truck series start (Seattle Post-Intelligencer) trucknews Truck News (headlines) 0 11-18-2004 10:30 PM
