Old 07-05-2008, 09:34 AM   #1
Herleman is on a distinguished road
Front Shock rattle 0n 05 Silverado
Hi folks -- I did a search and found nothing but here's my problem.
I have an 05 Silverado regular cab short bed V6 5spd with what sounds like a left front shock absorber rattle. I've inspected and found nothing out of the ordinary.
I'm told there may be a "fix" for this in the form of some sort of nre shock absorber bushing but the local dealers plead ignorance on the subject and seem as puzzled as I am about the noise.
Its getting worse and I'm worried that something may break.
It started at about 28K miles and the truck now has 29K on it and the noise is very noticeable and cam be "felt" through the steering column, especially when turning left or when pulling out of the driveway down the curbing.
Any ideas????
Herleman is offline   Reply With Quote
Old 07-05-2008, 10:40 AM   #2
stumpuller454's Avatar
stumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud of
another thing that is common is the bushings that support the caliper pins for the brakes wear out too, see if you can moove your caliper up and down, should be pretty firm, i have also seen the upper control arm cam bolts come loose, more so on the 4x4s though, plus i`d aso check your swaybar links they can rattle too if worn....
Old 07-05-2008, 11:17 AM   #3
z07
z07's Avatar
z07 is a glorious beacon of lightz07 is a glorious beacon of lightz07 is a glorious beacon of lightz07 is a glorious beacon of lightz07 is a glorious beacon of lightz07 is a glorious beacon of light
The cruise control module can sound like two pot-pie tins stuck together with a marble inside and it's in that general area too. Give it a couple of slaps and see if the sound is familiar.
Well as far as the feeling it when you drive tho... This wouldn't be it at all.
Old 07-05-2008, 03:49 PM   #4
jimbo543 has a spectacular aura aboutjimbo543 has a spectacular aura about
intermediate steering shaft splines lack of lube. unhook by your feet, move in/out a few times, rehook and drive noise will be gone.
jimbo543 is offline   Reply With Quote
Old 07-07-2008, 07:48 AM   #5
Its still under factory war, take it back, tell them to fix it and if they don't call customer service and open a complaint file.
Shock ideas? 97 Workhorse GMC Truck Forum 3 05-29-2008 12:44 PM
shock replacement scsgodfather Chevy Truck Forum 4 05-12-2008 09:55 AM
shock question vikes87 Chevy Truck Forum 5 08-03-2007 12:07 PM
Silverado 03-06 front clip mkylexl Chevy Truck Forum 0 02-07-2007 08:15 PM
Shock Installation Help!!!! YngPiggyZ71 General Truck Forum 0 03-11-2005 02:32 PM
