Old 07-07-2008, 12:48 PM   #1
shad9876 is on a distinguished road
Replaced the steering column and now truck won't stay running??
I replaced the steering column on my 2001 chevy 1/2 ton 4x4 and now it won't stay running. It just starts and then dies.
Any ideas?
shad9876 is offline   Reply With Quote
Old 07-07-2008, 01:06 PM   #2
03chevy's Avatar
fuel pump, fuel filter, or regulator is bad one of the three is your problem
Old 07-07-2008, 01:18 PM   #3
z07
z07's Avatar
Do the electric devices that only work when the key is in the "Run" position fucntion normally? power windows etc? Do 2001's have the VATS chip in the ignition key?
Old 07-07-2008, 01:19 PM   #4
if we go with the theory that the column removal was the cause, then i would have to say the ignition harness or your passlock. does your key have a chip on it?
i'd rather be hunting
Old 07-07-2008, 01:21 PM   #5
Welcome to the site;
The relationship between the column and the stalling would lead me to believe that there is an electrical problem.
When exactly does this thing die? Does it fire then die as you let go of the key? Returning the key to the run position might cause the loss of 12 volts from the ignition switch, and you are losing spark.
A little better description might help.
For what reason did you decide to change the column? Is the column exactly the same? Could there be a wiring change that could have caused this problem?
Old 07-07-2008, 01:58 PM   #6
Chevy_Finatic79's Avatar
maybe you just need to adjust the ignition pushrod switch it could have got moved during the R&R
85' Chevy C-10 Longbox (Rat)
TBI 327 Cu.In./THM350
90' Chevy Suburban 4x4
TBI 350 Cu.In./700R4
Old 07-08-2008, 03:02 PM   #7
I finally just put the ignition from the original column into the replacement column and now it works fine.
Steering Column Housing TZR2 Chevy Truck Forum 4 05-05-2007 01:37 AM
steering column swap out help viperman Chevy Truck Forum 2 04-30-2007 03:15 PM
83 gmc not wanting to stay running well cold joeydeherrera54 GMC Truck Forum 2 04-13-2007 06:46 AM
Truck will start but wont stay running PickUpGirl787 Chevy Truck Forum 6 12-29-2006 11:08 AM
Steering column vibration in 92 4x4 mochester Toyota Truck Forum 3 05-20-2006 11:27 PM
