Old 07-10-2008, 07:59 AM   #1
hootis is on a distinguished road
1994 1500 won't start
1994 Chevy 1500 ext cab, 5.7
let me give a little backround:
changed oil and plugs before long trip hauling camper and ran fine, then wouldn't turn over at all last week, tested battery and wouldn't take a charge, so replaced. alternator wouldn't even show reading on diagnostic at auto zone, but engine died on disconnecting negative battery cable, so replaced alternator and serpentine belt.
pulled fine to destination, ran fine. got home, parked in front of the house to move the van and put the trailer away, then the truck turns and turns, but won't start.
I replaced the fuel filter. I replaced the relay. After I replaced the relay, the injectors are making a strange clicking/buzzing sound when I give it gas. Is that normal? I never noticed it before. Still won't start.
I assume it is the fuel pump itself, but thought I'd make sure that injector sound is normal and see if there is anything else to consider before I go dropping the tank for a new pump.
thanks!
hootis is offline   Reply With Quote
Old 07-10-2008, 06:43 PM   #2
junior3382's Avatar
When sitting in the drivers seat, door open and no radio, and you turn on key to "on", but do not turn it over, can you hear the fuel pump turn on? If so, that is not your problem. If not, you are right.... I do not know about the sound of the injectors, I have never actually listened myself.... But some of the other vetrans here may know the answer to that.
Parts have been found, tools are collecting, tensions are rising, the weather is changing...look out.... the SAS is comming!
Old 07-10-2008, 07:16 PM   #3
thanks. i just went out and turned the key on, listened. turned it back on a (probably to the amusement of my neighbors) and listened in the gas fill and underneath. tried a couple whaps with a rubber mallet, too. nothing. when I put a good amount of choke cleaner in, it starts momentarily, so I'm gonna drop the tank and try a new pump.
I just planned on going with the pump and filter, not the whole wiring harness, bracket, etc. ($60 versus $250). do you think that would be okay? thanks again for your input.
Old 07-10-2008, 10:20 PM   #4
Faster4344 will become famous soon enough
yep just try replacing the pump ont the whole sending unit that seems to be ur problem. I mean you should definately hear it. And may i sugest an ACDelco pump!! i have had bad luck with aftermarket
Faster4344 is offline   Reply With Quote
Old 07-14-2008, 08:52 AM   #5
done
well, it was the fuel pump. got it replaced and runs like a champ. and only cost me about $58 with a new strainer, too.
man, that is a pain in the butt with half a tank of gas!
I did notice the strap in the front bending, twisting quite a bit while getting the big "T" bolt off. I'm kind of concerned that this weakened the heck out of that strap metal, but it seems okay... glad to be done with that job.
thanks for the advice.
Old 07-14-2008, 09:09 AM   #6
03chevy's Avatar
glad you got it fixed. next time syphen out some of the gas. just think if you had a full tank. trust me it makes the job much easier
03chevy is online now   Reply With Quote
Old 07-14-2008, 10:38 AM   #7
yeah, I learned a lesson on that one. that's heavy as heck when you don't have a lift to put the truck in the air. working laying on the ground it is tough to get moved up and down.
1994 F150 5.0L Won't Start... TexasCowGrower Ford Truck Forum 9 01-12-2008 05:04 PM
1994 Silverado 1500.....axel spline 28 or 30? Dennis Chevy Truck Forum 1 07-17-2007 01:21 PM
1994 1500 4X4 transfer case lock out switch Old Trucker GMC Truck Forum 5 02-05-2007 11:54 AM
1994 chevy 1500 cam swap jag9177 Chevy Truck Forum 5 01-13-2007 07:41 PM
Motor in my 1994 Dodge Ram 1500 4x4 mikejr1226 Dodge Truck Forum 12 02-22-2006 09:59 AM
