| Full Member Join Date: May 2008 Location: TEXAS
| 96 K1500 Ext cab, 5.7, auto...No dash lights According to my hayne's manual, there is a 5A fuse coming off the dark green wire from the headlight/dimmer switch assy. Does anyone know where this fuse is located? I have replaced the switch assy to no avail. In the schematic, it is labeled "PNL LPS FUSE". The wire on the other side of the fuse is grey and goes to the Heater/AC, radio, and instrument cluster lamps. JR |
| Senior Member Join Date: Dec 2007 Location: Really FAR NORTH!
| if you open your drivers door there is a fuse assy on side of dash, cluster fuse should be in there, i`ll take a pic of mine to show you...do your exterior lights work? i think they are on the same fuse.
__________________ Red seal certified Journeyman Automotive Mechanic Supercharger comming soon! |
| here the dash fuses anyways
| 1 20a stop/haz 2 20a t case 3 20a ctsy 4 10a gauges 5 10a rr hvac 6 10a cruise 7 25a aux pwr 8 10a crank 9 20a park lps 10 10a air bag 11 25a wiper 12 25a htr-ac 13 20a cig ltr 14 10a illum 15 20a drl-fog 16 20a turn-b/u 17 10a radio 18 10a brake 19 10a radio batt 20 10a trans 21 - - 21 - - 23 25a rr wiper 24 25a 4wd A 20a pwr accy (p/u) 30a pwr accy (util) B 20a pwr wdos (p/u) 30a pwr wdos (util) It is labeled as a 5A fuse, which none of these are. all of these fuses are good, but my ac/htr control lights don't light up nor do my dash lights. JR |
| hmm, sorry, i guess i dunno, only aware of in dash and underhood fuses, *so you replaced your switch on the column or the dash?* nothing happens when you roll the dimmer switch? does the interior lights come on when you roll it all the way?
| I replaced the headlight/dimmer assy on the dash. Nothing happens in the area that controls the panel lights, but when you roll the wheel all the way the interior lights come on. JR |
| WEIRD, i`m gonna say its your multifunction switch on the column can cause this problem, its an expensive part though, may wanna take it somewere to be verified...
| Dimmer Switch/Dash Lights? | Joe | Chevy Truck Forum | 6 | 04-19-2008 12:34 PM |
| 1986 Dash lights | radioguy | Toyota Truck Forum | 7 | 11-12-2007 12:44 AM |
| Dash Lights | GaBear | GMC Truck Forum | 1 | 07-29-2007 11:03 PM |
| Dash Ligts and Tail Lights out | Motorcycle | Nissan Truck Forum | 0 | 04-05-2007 06:15 PM |
| No dash or tail lights - ? | Donut John | Introductions | 3 | 01-05-2007 11:00 PM |
