Old 07-17-2008, 02:25 PM   #1
ssgtnelson is on a distinguished road
86 gmc 2500 electrical
hey I cant seem to keep a charge in my battery. I have replaced the alternator and the battery itself and have gone over all the ground connections and they seem to be in order. I need some help
ssgtnelson is offline   Reply With Quote
Old 07-17-2008, 02:41 PM   #2
seems as if you have a something draining your battery. with everything turned off, go one circuit at a time until you find something drawing power. i hate electrical work.
Old 07-17-2008, 03:09 PM   #3
yeah me too... should I work from the circuit panel or from some other spot?
Old 07-17-2008, 03:13 PM   #4
fuse box is fine. good place to start. if nothing there, might have to dig a little deeper as it might be a contactor that is fried and is grounding. have you noticed anything staying on or acting up and not functioning??
Old 07-17-2008, 03:16 PM   #5
CharlyG will become famous soon enough
If it is draining in a short time, you could just unhook the pos side and notice the size of the spark when you touch the pos to its terminal. If it takes overnight to drain, this won't be a good test, but if you have a huge drain, you will see a corresponding huge spark! Just a dumb shade tree trick I used to do.
'98 Chevy 2500HD ECLB, 5.7L, 4L80E, 3.73
CharlyG is offline   Reply With Quote
Old 07-17-2008, 03:27 PM   #6
well the thing is it doesnt drain when the truck is off but it wont recharge while its running so every time I start it i lose some juice and i get left at the most inconvenient spots
Old 07-17-2008, 03:43 PM   #7
when you replaced the alternator, did you have it tested?? have you thought about testing this new one?? make sure your plugs are connected good and cleanup all your ground connections to make sure you are getting a good ground.
Old 07-17-2008, 03:48 PM   #8
Chevy_Finatic79's Avatar
do you have access to a multimeter?
**WITH THE VEHICLE OFF**
set the meter to read AMPs
  1. Remove the negative side battery cable from the negative battery terminal.
  2. Attach an ammeter(this measures amperage) between the negative cable and the negative battery post. wait a few seconds to several minutes for the car to go into sleep mode. i.e. when you make the contact with the test light the cars computer systems "wake up" after a bit of time they will go to "sleep".
  3. If the ammeter is reading over 25-50 milliamps, something is using too much battery power.
  4. Go to the fuse panel(s) and remove fuses, one at a time. Pull the main fuses (higher amp ratings)last.
  5. Watch for the ammeter to drop to acceptable drain. The fuse that reduces the drain is the draw. Consult the owners' manual or service manual to find what circuits are on that fuse.
  6. Check each device (circuit) on that fuse. Stop each lamp, heater, etc. to find the drain.
  7. Repeat steps 1&2 to test your repair. The ammeter will tell you exact numbers.
EDITERS NOTE: The original author listed this repair using a 12v test light. As an ASE certified mechanic, the best place for your test light is the trash. A test light doesnt measure voltage; it shows if enough voltage is present to light the lamp.
  1. An ammeter meaures current (in amps), and that is what you are fighting against if you have a parasitic drain problem.
  2. Harbor freight sells a $3 digital multimeter (dmm) that has an amps setting. I use a Fluke, but it's whatever your trying to spend your dollars on.
[edit] Tips
  • A parasitic drain is when an electrical device is using battery power when the car is closed, and the ignition key removed. Therefore, when doing this test make sure that the dome light, under hood light, trunk light, etc. are off.
[edit] Warnings
  • Don't forget to check inside cigarette lighter and power sockets. Sometimes coins can fall in and cause shorts.
  • Some after-market alarm systems may make this test too long or loud to be worth the effort. If that's the case, seek professional help.
  • Be careful working around the battery in a car.
85' Chevy C-10 Longbox (Rat)
TBI 327 Cu.In./THM350
90' Chevy Suburban 4x4
TBI 350 Cu.In./700R4
Old 07-20-2008, 10:15 AM   #9
I suspect its a rebuilt, take the alternator back to where you bought it and exchange it. Tell them its not charging as it should, probably a bad regulater
95 s-10 electrical problem joshuapa Chevy Truck Forum 4 03-31-2008 07:27 PM
86 k-10 electrical HELP maddog Chevy Truck Forum 11 02-25-2008 03:18 PM
01 dodgd electrical felix Dodge Truck Forum 3 02-05-2008 01:13 PM
electrical nightmare mudseeker GMC Truck Forum 12 11-29-2007 09:57 PM
Electrical fisher429 Chevy Truck Forum 0 02-26-2006 06:54 PM
