Old 07-20-2008, 11:20 PM   #1
pthompson7's Avatar
pthompson7 is on a distinguished road
95 1500 4x4- Electrical Nightmare
I was pulling my wave runners back from the lake, as we have done lots of times. When I got in fromt of the garage, my truck stalled. I tried to start it and it wouldnt crank. When the key was turned, the motor turned about a 8th of a turn then nothing. As I was cranking the wire that runs from the under hood light started smoking and pretty much burned up as far as I was able to see (the black wire). I thought I may have trashed the starter, so we replaced the starter......nope that was good. We still have the problem. We pulled off the serpentine belt to see if it would crank and we were able to start it with the belt off. Put the belt back on and no crank. We were able to push start it and it ran for a few minutes. I started to take it for a test drive and pulled to the street and it died. I parked it and am not sure where to start. Manual trans. 4.3 V6, it was sounding like the bearings in the AC compressor were going, but would that cause the wire to burn up like that?
I would appreciate any assistance I can get on this one.
pthompson7 is offline   Reply With Quote
Old 07-21-2008, 04:33 AM   #2
It sounds like you have a bad ground. Check battery grounds and engine to frame/body grounds. These should all be clean and tight.
Old 07-21-2008, 06:21 AM   #3
Chevy_Finatic79's Avatar
Chevy_Finatic79 is a name known to allChevy_Finatic79 is a name known to allChevy_Finatic79 is a name known to allChevy_Finatic79 is a name known to allChevy_Finatic79 is a name known to allChevy_Finatic79 is a name known to all
if your A/C compressor clutch locked/seized up then yes you will not be able to run the motor with the belt on. when had the belt off could you turn the A/C pulley/clutch freely by hand? if not thats probably your problem
as for the hood light you got me
85' Chevy C-10 Longbox (Rat)
TBI 5.7 Liter/THM350
90' Chevy Suburban 4x4
TBI 350 Cu.In./700R4
Chevy_Finatic79 is online now   Reply With Quote
Old 07-21-2008, 06:51 AM   #4
had a similiar problem with a neighbors 4.3 it was the alternator siezed.. pull the belt back off and see if all the pullys spin on all accessories
Old 07-21-2008, 08:02 AM   #5
stumpuller454's Avatar
stumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud of
^ yeah and also check for a short to ground in your underhood light
Red seal certified Journeyman Automotive Mechanic
Supercharger comming soon!
Old 07-21-2008, 03:23 PM   #6
pthompson7's Avatar
Hey guys,
I removed the belt and all pulleys are moving freely, so there goes my theory on the AC compressor. (I think) I am trying to trace the shorted wire, (the underhood service light) to see if I can trace it to it's source.
Is there anything else that may be causing this problem, aside from the starter?
Here is something else that is wierd, when I have the key in and the accesories on, the guages go crazy when I try and start the truck. The Oil and Battery guage go all the way to the right and the fuel and Temp go all the way to the left. It sounds crazy, right?
Update, I was just out looking things over and doing some checking. There is a ground wire that runs from the passenger side, rear of the motor, to the chasis, but it was laying on the exhaust manifold and burned in two. Is this a result of a bigger problem, or the problem?
Help!!!!
Old 07-21-2008, 06:23 PM   #7
So does it still start with the belt off?
Old 07-21-2008, 06:45 PM   #8
pthompson7's Avatar
Well, here is the results. What happened was the main engine ground wire was laying on the exhaust manifold. The melted through and the electrical system found the under the hood light ground wire to be the path of least resistance. I replaced the ground wire and taped up the ground wire fro the under the hood service light, and it runs fine. I just dont have that handy light under the hood. How important is it that I trace the light ground wire.
Thanks
Old 07-22-2008, 05:45 AM   #9
Glad to hear you got it fixed. As far as the ground wire to the light is concerned it is only important if you want the light.
Old 07-22-2008, 02:41 PM   #10
pthompson7's Avatar
Thanks Guys. I really appreciate your help.
electrical nightmare mudseeker GMC Truck Forum 12 11-29-2007 09:57 PM
Electrical Nightmare Boat guy GMC Truck Forum 6 07-05-2007 08:10 PM
Bracket Nightmare BillySuburban GMC Truck Forum 5 03-09-2007 11:44 PM
97 Dodge 1500 4 X 4 electrical problems Phil Herr Dodge Truck Forum 3 02-11-2007 09:58 PM
90 gmc sierra 1500 electrical problem ducorse GMC Truck Forum 3 11-28-2006 01:14 AM
