| | #11 |
| could be a high pressure switch on the dryer acting up...not give proper voltage to the clutch..or the clutch is getting weak which is replaceable with the proper puller |
| | #12 |
| Full Member Join Date: Jul 2008 Location: Tennessee
| Could the High Pressure Switch cause the clutch problem? When the clutch kicks off I still have power to the compressor on hot and ground wire, when compressor is off you are not suppose to have power to the clutch i thought? I'll check my connection on the pressure switch, maybe the plug has a problem with it. |
| | #13 |
| Yes you are correct. I've seen where the connection at the switch becomes intermitent. leave the ignition on and play with the wires if its acting up you will hear the clutch activating and deactivating. Did you notice any rust etc at the clutch when it engages? As I mentioned you can replacew the clutchand not mess with the gas side of the system. |
| | #14 |
| Well I wiggled the wires on the pressure switch and it did nothing, so I took a paper clip and stuck it in both female prongs of the pressure switch plug and the compressor would not kick in, and it should have I think. My plug has a little fraded place on it but I don't think it is bad enough to cause the problem, I will order a new one and change it out and see if that fixes it. Thanks again for your help. I will post again when I find something wrong. |
| | #15 |
| when you bypass the switch and you tap on the clutch, if it engages I'd be looking at replacing the clutch assembly |
| | #16 |
| Senior Member Join Date: Jun 2008 Location: kentucky
| How does it do when you are just setting idling? I would put gauges on the system and watch it. Gauges should read equal which system is off. When on low should drip to around 30-50 psi depending upon several conditions while high should go up to around 170-200psi depending upons the same conditions. All units work generally the same but there are minute differences. It does sound like the fan clutch is not dissapating enough heat from the condenser at slow speeds or idle, then when the rpms are increased it helps to dissipate the heat from your condenser which in turns cools the freon which is sent back to your evaporator for cooling the inside of your vehicle. so for being so wordy, but I'm a school teacher......
__________________ MY first truck was a FORD.......I've owned Chevy's ever since. 1995 K2500 4x4 5.7L Cheyenne 1991 T-10 Blazer 4.3L Tahoe Package 1998 Oldsmobile Bravada 4.3L Vortec Smart Drive |
| | #17 |
| And I am ashamed of all the mispellings as well...
| | #18 |
| Also check your condenser for bugs & weeds and such...it could be stopped up. It.s directly in front of your radiator.
| | #19 |
| Pulled Vacuum on system, changed orfice, replaced dryer, checked clutch, (was okay), and put in new Freon, still same problem. Also changed plug on dryer that was frayed a little, I give up. ![]() |
| | #20 |
| John I found one from a S-10 there the same thing Ebay, people were biding like crazy for the used one's for our trucks but I found out that the S-10 fits and I paid barley nothing. Hope this helps! GMC |
| 99 Explorer XLT AWD 5.0 V8 Immaculate Condition! | NxNW | Truck Classifieds | 1 | 05-26-2008 10:09 AM |
| Just picked up a 82 C10, it is good condition but needs some work | liquidsmile | Chevy Truck Forum | 5 | 06-23-2007 11:21 PM |
| Dodge 4X4 Good Condition, 1993 Diesel | Dodgetruck246 | Truck Classifieds | 0 | 06-11-2007 10:51 PM |
| Baby In Critical Condition After Being Hit By Truck (WKYT) | trucknews | Truck News (headlines) | 0 | 04-18-2005 07:30 AM |
| Lost truck driver found in good condition (Yreka's Siskiyou Daily News) | trucknews | Truck News (headlines) | 0 | 11-16-2004 03:30 PM |
