Old 07-21-2008, 08:25 AM   #1
Johnboy is on a distinguished road
Air Condition Problem
I have a 1990 Model 4X4 1/2 Ton Truck, the Air Condition works fine at the start but after it is on for a few minutes it starts blowing hot air. If you press the accelarator down then it starts blowing cold air again, must be a vacuum problem somewhere. I think on a steady run down the road it finally loses vacuum and when you hit passing gear it starts making cold air again, is there some kind of vacuum valve under the dash that may be bad? The Freon is full in the unit, compressor and all that is okay, has anyone ever seen this kind of problem before? Any help will be greatly appreciated.
Johnboy
Johnboy is offline   Reply With Quote
Old 07-21-2008, 11:49 AM   #2
Moderator
bradrhale has much to be proud ofbradrhale has much to be proud ofbradrhale has much to be proud ofbradrhale has much to be proud ofbradrhale has much to be proud ofbradrhale has much to be proud ofbradrhale has much to be proud ofbradrhale has much to be proud of
if your blend door is vaccuum operated, you might have a leak that wont let it operate. when you have high rpms, she will build up enough to actuate it. that or your unit is overcharged.
Old 07-21-2008, 02:21 PM   #3
leolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud ofleolkfrm has much to be proud of
How do you know the charge status what kind of pressure on the low side, was it recently evaped and recharged? or just added to? did the problem start all at once or gradually?
Old 07-21-2008, 02:28 PM   #4
flyballman is on a distinguished road
make sure your condenser isn't clogged or that your fanclutch is working properly, you might be building up to much heat
flyballman is offline   Reply With Quote
Old 07-22-2008, 05:41 PM   #5
Well I had the Compressor Checked, it's okay, clutch is fine, plenty of Freon and Oil in Unit. As for Vacuum hoses there are none, it's all Electronic, there is one down on the left on lower heater box next to gas pedal, and one behind the glove box, have to take glove box out to get to it. Dealer tells me ther is no vacuum hoses on 90 chevy 4x4, it all is electronic, may be losing voltage, sounds strange to me though, anyway I will look at them and see if it appears to have a problem, will check volts when running. Thanks so far for the replys.
Johnboy
Old 07-22-2008, 05:43 PM   #6
That is correct they are servo operated, the one on the lower box changes from das to def etc. the one behind the glove box is the one to check
Old 07-22-2008, 05:48 PM   #7
If I look at it and see nothing Visual, could it still be bad, I am sure it is going to be a sealed unit?
Johnboy
Old 07-22-2008, 05:51 PM   #8
manually move the damper and see if the air works correctly
Old 07-22-2008, 06:29 PM   #9
gmctrucks is a splendid one to beholdgmctrucks is a splendid one to beholdgmctrucks is a splendid one to beholdgmctrucks is a splendid one to beholdgmctrucks is a splendid one to beholdgmctrucks is a splendid one to beholdgmctrucks is a splendid one to beholdgmctrucks is a splendid one to behold
My 93 F/S GMC would start blowing hot air then it would start blowing cold air after a while, well it turned out that I was low on Freon and it was freezing up and when it would thaw out it would work good again till it would do the same thing again, again, and again.
Old 07-22-2008, 07:43 PM   #10
Well everything I have checked is working properly, servos are good. Now I think I have figured it out, when the compressor kicks off I still have power on the hot and ground where the wires plug into the top of the compressor. If you tap on the side with a small hammer it goes again, I guess it must be heating up and kicks out, but I don't understand why I still have power. I checked the diode in the clutch part of the compressor and it is good, any ideas from anybody? Can there be a fix wiothout changing compressors? Looks like to change just the clutch parts and wiring may be a problem, not always a good fix, looks like I may have to change compressor, oh well. Maybe someone else may have a option, Thanks for the replys.
99 Explorer XLT AWD 5.0 V8 Immaculate Condition! NxNW Truck Classifieds 1 05-26-2008 10:09 AM
Just picked up a 82 C10, it is good condition but needs some work liquidsmile Chevy Truck Forum 5 06-23-2007 11:21 PM
Dodge 4X4 Good Condition, 1993 Diesel Dodgetruck246 Truck Classifieds 0 06-11-2007 10:51 PM
Baby In Critical Condition After Being Hit By Truck (WKYT) trucknews Truck News (headlines) 0 04-18-2005 07:30 AM
Lost truck driver found in good condition (Yreka's Siskiyou Daily News) trucknews Truck News (headlines) 0 11-16-2004 03:30 PM
