Old 07-30-2008, 05:19 PM   #11
hotrodpc is just really nicehotrodpc is just really nicehotrodpc is just really nicehotrodpc is just really nice
I will make that suggestion to my bro about the K&N and Flowmasters. I am sure speed makes a big differance if you are going 60. Believe it or not, I can tell a differance in fuel mileage from 72mph and 75mph. We also forget, more speed = more wind resistance and to be at just the right RPM for maximum fuel efficiency depending on engine timing, igniton timing, cam dimensions and gear ratios.
Old 07-30-2008, 06:01 PM   #12
schweikertcharl's Avatar
schweikertcharl will become famous soon enough
Don't forget about octane levels. I run 92 octane. At 87 I see a reduction in mileage as well as performance. Let your bro know too that with changing the exhaust, to have a tech set up the emissions cpu for the type of exhaust he is running.
schweikertcharl is offline   Reply With Quote
Old 07-30-2008, 06:06 PM   #13
Also have him check out gmtuner.com
Tons of tech for the 8.1 as well as 6.0 and 5.3
Old 07-30-2008, 08:39 PM   #14
10-4 Thanks for the info. I was aware to reprogram the PROM Chip in the ECM when you make changes to the exhaust. Should probably be done for even on the K&N air intake too or it would give funky readings to the MASS air flow sensor and even possible I guess for the MAP sensor too. Give all kinds of funky reading and send out bad instructions to the engine timing and a/f mixtures and hurt fuel mileage rather than help.
Old 08-04-2008, 12:16 PM   #15
Fatcat is on a distinguished road
hmmm..... size
Fatcat is offline   Reply With Quote
What is the difference between the 22r and 22re? Chevy_Finatic79 Toyota Truck Forum 14 07-21-2008 10:06 AM
Chevy Engine ID help NCmau Chevy Truck Forum 6 01-26-2008 09:19 PM
5.7 Chevy short block any difference? KeckWerkes Chevy Truck Forum 3 08-11-2007 04:52 PM
Whats the difference? anyone? ikos10 General Truck Forum 5 03-19-2007 05:20 PM
difference between 305 and 350 computer splinter Chevy Truck Forum 4 10-26-2005 08:48 PM
