Old 07-31-2008, 03:37 PM   #1
Hamneggs's Avatar
Hamneggs is on a distinguished road
Brake Light Stays On - 98 Silverado
1998 C1500 Silverado 5.7L Vortec
I had a tiny brake line leak and reservoir went empty over time.
Pedal went to floor, and dash brake light was activated.
Fixed leak, refilled reservoir, brakes working fine, but brake light on dash is still on.
What is procedure to get the durned thing to shut off?
Hamneggs is offline   Reply With Quote
Old 07-31-2008, 04:05 PM   #2
Hamneggs's Avatar
Just found this in another thread:
"It may be that the pressure diferential switch needs reset. Try opening a rear bleed screw and get a helper to gently press the pedal. If the light goes out tighten screw and let pedal up. If light does not go out repeat with a front bleed screw. It is a matter of getting the valve reset to the central position. It may have been pushed to one side or the other when you flushed the system."
Sounds like this applies to my issue.
Old 07-31-2008, 04:15 PM   #3
mod-o-tator
yup, that would be your problem, or you have a bad low fluid sensor.
you may want to take it to a shop with a scan tool to be sure that is the problem.
member map add yourself
alldatadiy
Old 07-31-2008, 06:34 PM   #4
rdhack's Avatar
rdhack will become famous soon enough
Just a thought....pull up on your emergency brake pedal...sometimes they do not release all the way.
MY first truck was a FORD.......I've owned Chevy's ever since.
1995 K2500 4x4 5.7L Cheyenne
1991 T-10 Blazer 4.3L Tahoe Package
1998 Oldsmobile Bravada 4.3L Vortec Smart Drive
rdhack is offline   Reply With Quote
Old 07-31-2008, 07:22 PM   #5
Hamneggs's Avatar
Thanks...I tried that. Pretty sure it's that valve thingy, cuz it happened just when my brake pedal bottomed out. I just didn't know how to get it back right again.
I'm wondering though....if that metering valve is hyper-extended, does that mean I've only been getting brake action on one set of wheels?
Old 08-01-2008, 10:36 AM   #6
athe pressure diff. valve should be just below the master cylinder with a single wire connection. You may be able to reset it by pushing the little rubber button in, if not follow the proceedure you highlighted. Also if you pull the wire off and the light goes out you know it is the valve needs to be reset to center. And this valve does not alter your brakes at all.
Old 08-01-2008, 01:57 PM   #7
Hamneggs's Avatar
Useful info, Case. Thanks.
I'll take a look at it this weekend.
1998 Chevy C1500 Silverado
1970 Mercury Cougar XR7 (Project)
http://i40.photobucket.com/albums/e228/HamneggsSilverado/photo008b2.jpg
Old 08-01-2008, 02:00 PM   #8
Just another thought, The truck is 10yrs old, When you did the master, did you bleed all the brakes till there was fresh fluid flowing? or basically flushed the system?
over time the fluid starts to turn brown and thicken, which creates other problems. As I said just another thought
Old 08-02-2008, 01:32 PM   #9
Hamneggs's Avatar
Pulled wire connector, light went off.
Pressed that button, a lil fluid came out. It was a rubber cap over a needle valve thingy. No change with light.
I'll just go through the bleed procedure described above.
Old 08-02-2008, 04:01 PM   #10
mod-o-tator
wish i would have thought of this before. but you may need to take the truck to a shop and have them purge the abs system with a scan tool. for some reason i thought you said it was an 88, not 98. since you ran the master out of fluid, you probably have air in the abs system and the easiest way to get it out is with a scan tool. once your truck info is entered into the tool, it takes less than a minute to purge the system.
you can also do it manually, but i never bothered to learn it since it takes more time and time is money when it comes to fixing things.
alldatadiy
Tags
brake light
1990 GMC Brake Light Stays on and Engine Stalls b.hayz1 GMC Truck Forum 24 07-25-2008 09:47 PM
Change oil light stays on PopPopCassidy Chevy Truck Forum 6 03-17-2008 06:41 AM
88 silverado dash brake light joecuccovia Chevy Truck Forum 6 03-02-2008 04:21 AM
Overdrive light stays on 93 Nissan Detailer054 Nissan Truck Forum 0 01-08-2008 07:48 PM
air bag light stays on 1995 1500 larbec7 Chevy Truck Forum 12 05-30-2007 08:08 PM
