Old 08-02-2008, 08:54 PM   #1
Flopeyeman is on a distinguished road
Quick Transmision Question
I have a 1988 Chevy Silverado standard cab with a step side bed. It is a 350 with the 700R4 My question is how hard would it be to put a High Performance Shifter on the floor?
Flopeyeman is offline   Reply With Quote
Old 08-02-2008, 09:23 PM   #2
mod-o-tator
how would you reach it? it's not like a car where you almost sitting on the floor board. it's annoying enough to reach for the t-case shifter once in awhile, couldn't imagine doing it every time i got in the truck.
i guess you could rig it up like a manual shifter, but then you would need to fab up a locking mechanism to keep it from popping out of/into gear by accident.
member map add yourself
Old 08-02-2008, 11:36 PM   #3
Mudseeker makes a very valid point, but to answer the question, it is a very simple install, and most performance aftermarket companies haver everything you need to acomplish this. They will come with the appropriate cable, and brackets to connect everything.
Be sure you purchase a shifter that has 1 additional gate to accomodate the 4th gear.
This will permit the full range of grears.
Some three seed only shifters will not work, but most are now in compliance with4 speed autos.
Old 08-03-2008, 01:05 AM   #4
hotrodpc is just really nicehotrodpc is just really nicehotrodpc is just really nicehotrodpc is just really nice
I had a truck and used the B&M Quicksilver ratchet shifter and although I have long arms it was not a big reach for me and became second nature in no time. However, the Quicksilver at that time was for 3 speed autos and I am not even sure if they still produce it. The Quicksilver did have a bit taller stick than others like the Zgate. As above, it should be an easy install. They come with the brackets, back up light switch, park/nuertal switch and all. You will just have to figure out the wiring, and the instructions are likely to give you that info. Be sure to let us know what you found to use and how it looks and works out.
Old 08-03-2008, 11:15 AM   #5
Hey Flop, I think I found you a shiter. Here is some C&P info about it.
Item: B&M Light Truck Mega Shifter (Part #80680)
Description The classic MegaShifter design is a configuration that will fit your light truck! All the things you expect in a B&M shifter are right here and ready to install in your truck. The Truck MegaShifter includes a taller base and an adjustable floor mount bracket for proper installation.
Old 08-03-2008, 08:32 PM   #6
mod-o-tator
Bowtie Overdrives - View Item
i think you forgot to post the link, bud.
i need quick help... waterloo88chev Chevy Truck Forum 9 06-08-2008 09:40 PM
Quick Question on Electric fan claytonfrnk Chevy Truck Forum 2 04-29-2007 06:57 PM
Need a quick answer dzrick Chevy Truck Forum 3 12-02-2006 08:41 AM
quick question bubba8167 Dodge Truck Forum 2 11-21-2006 02:56 PM
Quick Question Wicked Customs Toyota Truck Forum 2 07-19-2006 05:37 AM
