| Junior Member Join Date: Aug 2008 Location: N.Georgia
| My tailgate hooks have been sticking in an open position so that the gate will not latch shut. I was told to lube the spring at each hook and at gate latch. Anyone ever had this issue? What lube should I use?...WD-40? Also, do I have to remove the 3 bolts from the inside of the bed to do this? Thanks in advance!!!!! MCGA |
| I have just shot them with WD-40 in the past, sprayed right in, and never had an issue. They stick ocasionally, it does work. I would not think you should have to rmove everything, unless you wanted to completely clean and lube everything. Welcome to the forum by the way.
| after you use wd40 and get it working good. put some grease in there so you will not have to worry about it for awhile
| the springs are not your problem, chevy has a poorly design tailgate handle. if you were to unhook the rods from your handle, i would be willing to bet a cold beverage that the latches would close like they should. you need to remove your handle and drill the factory rivet out and replace it with a bolt and nylock nut. New Truck Last edited by mudseeker; 08-03-2008 at 09:03 PM. Reason: spelling |
| what is it with people betting a cold drink all of a sudden? LOL.... There are minors on this forum you know! LOL....
| A cold beverage cold be a soda or some water lol |
| o right, maybe I should get my mind out of the gutter....LOL....
| Someday you might jr |
| Maybe... only time will tell! LOL...
| minors aren't a problem as long as i don't share it with them. |
| 2003 Chevy Silverado AWD Turbo | Deryl | Chevy Truck Forum | 0 | 05-21-2008 03:36 PM |
| 2003 Chevy C1500 2wd (5.3 Liter) | 06BLACKGMC | Chevy Truck Forum | 0 | 10-08-2007 01:19 PM |
| 2003 chevy 2500hd | brandpeto | Truck Classifieds | 0 | 03-28-2007 05:43 PM |
| Rear end lube ? | ibramin | Dodge Truck Forum | 4 | 11-22-2006 02:44 PM |
| 2003 Chevy 2500HD 4x4 | fireman649 | Truck Classifieds | 0 | 09-11-2006 06:28 PM |
