| | #11 | ||
| Full Member Join Date: Sep 2007
Thanks again, Guys! Jess
__________________ Stock 94 Silverado; extended cab; 5.7 | ||
| | #12 |
| There is a good website, I think it is oxygensensors.com good luck. |
| | #13 |
| Most gm o2's have about 8-10 in of wire attached are you sure you are looking at the right connection point? Smaller hands in some instances are the solution to hard to reach locations. They do make special sockets for sensor replacement, there is a cut down the side for the wires and make replacement much easier. |
| | #14 | |
| | #15 |
| have you tried to reach it by going through the wheel well. sometimes you can reach things like the starter and such by removing the wheel and lifting the rubber flap out of the way.
| | #16 |
| Senior Member Join Date: Jun 2008 Location: kentucky
| Best I remember I just wormed my hand up by the firewall and disconnected it. The wire should be long enough. Pull the slack out of it. Sorry for the delay in answering...You prob got it fixed by now I assume.
__________________ MY first truck was a FORD.......I've owned Chevy's ever since. 1995 K2500 4x4 5.7L Cheyenne 1991 T-10 Blazer 4.3L Tahoe Package 1998 Oldsmobile Bravada 4.3L Vortec Smart Drive |
| | #17 | ||
I will try the suggestions you made. I'll let you know. Thanks for the tip. Jess
| | #18 |
| Alot of times its a 1 handed reach and unable to see, but with patience and perseverance you'll get it |
| | #19 |
| Hey I think I may have figured out what is going on. On a 5.7L the O2 is supposed to be on the driver side where you initially looked. On a 4.3L it is where yours is now. I bet my farm someone has Afro-Engineered the one you are replacing by installing a jumper wires so you may have to do the same thing. I may be wrong but thats the only thing I can think of to why you are having so much trouble. I owned a 1994 4.3L and replaced the 3-wire O2 on the passenger side with relative little ease. I now own a 1995 5.7L and relaced the single wire O2 on the driver side also with relative ease. Hope this helps!
| Oxygen sensor | edward681 | Mazda Truck Forum | 2 | 10-15-2008 06:54 AM |
| DIY info on oxygen sensor replacement?? | Ladybug263 | Chevy Truck Forum | 29 | 10-24-2007 12:46 PM |
| Oxygen sensor on 2002 2500 HD | jhughes6060 | GMC Truck Forum | 2 | 10-15-2007 09:57 AM |
| 4 oxygen sensor codes | lugnut | GMC Truck Forum | 1 | 05-02-2007 01:58 AM |
