| Fuel Pump Doesn't Start (Sometimes) Sometimes the fuel pump in my '99 Chevy silverado (5.7L 350) will not kick on. I'm pretty sure my stepdad said he already replaced the fuel pump relay, but I may replace it again. What else could be the cause of this? Wiring? Where would I locate the right wires? Any help would be appreciated. Thanks. |
| Put a scan tool on it and see what kind of readings for, pressure switch, temp switch, etc one may be getting weak |
| The fuel pump not kicking On? bad ground? hmm can u hear it? did u check the coool on the distrib? Fuses?
__________________ //B-rad |
| Senior Member Join Date: Dec 2007 Location: Alberta
| Pumps probly toast, WAY to common....
__________________ 1998 GMC K2500 Ext.cab short box 454ci (supercharger coming soon!) 1951 Chevrolet 1420 pickup like new! Red seal certified Journeyman Automotive Mechanic |
| If pump is bad replace with Delco brand, after market pumps most of the times go out fast or don't work after you place everything back in place and you get to trying it then you have to do all the work again. |
| | #6 | |
| Senior Member Join Date: Jul 2008
__________________ 178k miles Looking to be in the 200k mile club The list of what hasn't been replaced is shorter than what has been replaced. | |
| carry a rubber hammer in truck at all time. my 2000, 2500 series with 350 engine came with a rubber hammer. Service tech told me if truck will not start and you do not hear the fuel pump, just get out your rubber hammer and hit fuel tank a few times, most times it will start and you can get truck back to dealership to have the $600 fuel pump replaced. Mine was replaced at 45K, truck now has 82K so I keep my hammer where i can get to it quick. also check fluid level in coolant reservoir, need to check it twice to every time you check the oil, if low, replace the intake manifold gaskets. good luck, |
| Senior Member Join Date: Nov 2005
| my 87 has an oil pressure switch and fuel pump will not start unless this switch is made. On mine the switch stuck in the on positon and fuel pump ran continuously for 8 hrs at work. It is a safety so that engine will not run without oil pressure, I guess. |
| Tags |
| fuel pump |
| need help with fuel pump 87 tbi | kkustomz | Chevy Truck Forum | 2 | 05-19-2008 06:04 PM |
| Fuel pump, fuel tank, filler neck, filter... | lassy | GMC Truck Forum | 6 | 04-11-2007 06:48 AM |
| another fuel pump | scvpiper | Chevy Truck Forum | 4 | 03-08-2007 11:41 AM |
| Fuel pump.. | mslwpk | Ford Truck Forum | 7 | 04-06-2006 06:39 AM |
| fuel pump | vanhal | Chevy Truck Forum | 3 | 02-09-2006 06:54 PM |
