| Senior Member Join Date: Dec 2007 Location: Michigan
| Gears for a Dana 44 Anyone have any suggestions as to the cheapest place to get a set of 4:10 gears for a dana 44 front axle on a 85 3/4 ton? I'm looking to get some cheap but don't want cheap quality. Thanks for the help. |
| How cheap? I mean a gear replacement will run ya close to 1500 bucks give or take regardless, what does it have now? Is this nescesary? There may be another solution.... so what is the end goal of doing this?
| RANDY`s RING AND PINION!!! checkem out online....lots of $$ options and all is good stuff, cheap too...
| Randy's is the way to go. Just keep in mind, you do get what you pay for. You might get lucky with a used set, but that is a crapp shoot. What gears are you currently running. If higher than 4:10, you may have to change your carrier as well.
| Thanks for the help guys I'll check them out. I'm running 4:10's and need to do the front end my ring gear is going out starting to take some teeth off of it. |
| gears | BigWill | 4x4 trucks / off road | 11 | 01-17-2008 04:39 PM |
| 2.73 to 3.08 gears | Donut John | Chevy Truck Forum | 6 | 12-07-2007 11:38 PM |
| dana 60 stearing knuckle seals....... | charlie g | Ford Truck Forum | 1 | 01-02-2007 03:17 PM |
| Dana 70HD rear diff with 4:10 gears | chevyguy | Truck Classifieds | 2 | 10-31-2006 11:09 PM |
| Dana Corporation Providing Axles and Driveshafts for General Motors 4x4 Medium-Duty Trucks (The Auto Channel) | trucknews | Truck News (headlines) | 0 | 11-10-2004 01:30 AM |
