| | #11 |
| will the motor run any better with the new oxygen sensor(s) adn i was lookiin in to getting the cat-back system from cherry bomb it sounds freakin sick on a 6.0 so it should sound just as good on my 5.3 and the k&n and i was lookin into electric fan(s) will a universal fan work from advanced auto or somthing they run around 87 bucks for one 16 inch fan |
| | #12 |
| Well I ment to say i got flowmasters on it, i got headers also. what you mean by carberated?
__________________ //B-rad |
| | #13 | |
| Senior Member Join Date: Dec 2007 Location: Really FAR NORTH!
All computer to nothing computer? just kinda assumed your not using fuel injection anymore? HC85, yeah anyfans will do, you will want to end up with at least 4500cfm (for a full size truck) of air movement, all fans are rated, you will probly have to use 2 fans, ALSO you will want to probly run a setup that incorperates a thermostatic switch that you can adjust to "turn on/off" the fans at the tempurature you desire, otherwise you could wire them to come on when the key comes on but they would run non stop, not lasting as long and cooling when not neccesary (cold start in the morning) I`ve got mine setup to be capable of turning on even when the truck is off, so after a long trip she will cool down well even after i`m out of the truck.
__________________ Red seal certified Journeyman Automotive Mechanic Supercharger comming soon! | |
| | #14 |
| Right im not fuel injection anymore.
| | #15 |
| well what about the o2 sensor will that help me or just leave it the way it is |
| | #16 |
| i don`t think changing the 02 is going to gain you anything, your computer monitors its performance and when it is out of range your CEL should come on. So BRAD what ARE you runnin under that hood? i wanna see!
| | #17 |
| Go 2 my pictures, its in there
| | #18 |
| the best way to get great mileage outta that baby is a 2 barrel!
| | #19 |
| AFF!!! what kinda gas mileage u think i would get? how much diff betwen 2 barrel and 4 and lets see what all do u think i should do 4 more gas mileage ? hmm what gas should i run in that motor? what about geting that carb adjusted for best gas mileage? wat u think? and wat u think abot my lil project truck xD
| | #20 |
| actually the two barrel has bigger primaries so ur better off just sticking with a q-jet and lean it out bit u might half to mess with the timing a little bit to get a little more bottem end out of it cuz when you lean a carb out it takes away from your bottom end if you want google it about the two and four i might be wrong |
| Tags |
| gas milage |
| bad gas milage :( | sandtiger | Mazda Truck Forum | 25 | 08-25-2008 03:02 AM |
| Gas Milage | chevy-eater | Off-Topic | 5 | 08-09-2008 05:45 PM |
| fuel milage | lucky | Dodge Truck Forum | 4 | 02-18-2008 02:35 PM |
| better gas milage | adamant | Dodge Truck Forum | 19 | 09-13-2007 04:53 AM |
| Milage | chevy-eater | Ford Truck Forum | 2 | 01-05-2005 11:59 PM |
