| B&M Shift Kit?? I am wanting to get some better shifting out of my 4L60-E without replacing it or rebuilding it. I've just recently been thinking about an shift kit for it. I dont know many of the pros and cons about it nor can i find much helpful info on it. Can any one shed some light on this for me? Thanks!! |
| Here's some info. Sonnax Servo 700R4 AODE 46RE Sonnax Transmission Parts 4L60E 700R4, 700 Raptor Transmissions by Performance Automotive and Transmission Center, 700R4 IF you are wanting a snappy shift.... use a TransGo 4L60E-HD2 shift kit. While you have the valve body down & 2-4 servo out , remove the check ball capsul in the servo bore. Install a 3/8 inch cup plug in it's place. Next time my trans shells out im replacing the sun shell with (The Beast) and some other HD parts. Be good! GMC |
| Well got the shift kit in, had a few dumb moments but went together real good, and holy **** did it make a difference!!! |
| Senior Member Join Date: Dec 2007 Location: Really FAR NORTH!
| yeah can`t wait to get my transgo 4L80E-HD2 kit in one of these days!
__________________ Red seal certified Journeyman Automotive Mechanic Supercharger comming soon! |
| Senior Member Join Date: Jul 2008
| What Kit did you go with Morrow? The B&M or the TransGo? What stage kit did you use? Stage 1 is usually RV/Towing Kit, Stage 2 is usually Street/Strip. And the unlikely Stage 3 being a full manual valve body. |
| if i would put a shift kit in my 85 700r4. i only tow haul and plow with this truck will the shift kit make my universal joints go bad |
| Street /Strip is going to hit HARD might go with RV stage. |
| sorry took so long to respond, was out all week end camping. i put a B&M in it and did the Heavy duty one. i pull alot and spend alot of time off roading. the difference is remarkable. when im off roading there is hardly any tire speed lost when shifting. and when pulling a load pretty much the same thing. wish i would of put one in a long time ago!! |
| I had one on a Firebird I had many moons ago it did real well now on my 1970 GTO it didn't need one but imagine if it did have one it would have broke my neck. LOL |
| Yes, you did the right stage Morrow. The RV stage is perfect for what you want and not going to be hard on the u joints. The street/strip mode will have been barking tires from 1st to 2nd leaving a light at about mid throttle. The RV kit offers a nice firm positve, right now ****, without suffering comfort (whip lash), barking tires and tickets for exhibition of speed. |
| Shift kits | heavychevy85 | Chevy Truck Forum | 10 | 08-30-2008 10:14 AM |
| shift linkage | yodaman | Ford Truck Forum | 1 | 04-03-2008 08:00 PM |
| Tranny won't shift | steven1213 | Chevy Truck Forum | 4 | 04-02-2008 05:54 AM |
| Shift Kits | WisconsinHick | Chevy Truck Forum | 6 | 02-26-2008 06:14 AM |
| shift indicator off | SilverK96 | Chevy Truck Forum | 11 | 10-06-2007 07:37 AM |
