Old 08-28-2008, 06:28 PM   #21
heavychevy85's Avatar
heavychevy85 has a spectacular aura aboutheavychevy85 has a spectacular aura about
i use walmart batts. i get the ones with free 3 year replacement the size of batt that i use is a 1000 or 990 they crank better in the winter i take mine batt back right before the 3 years is up they give you 9 bucks for the old one and you get a new one no charge i just tell them it don't hold a charge anymore they never realy throw a fuss
heavychevy85 is offline   Reply With Quote
Old 09-10-2008, 03:43 PM   #22
Brook is on a distinguished road
Just thought I'd follow up on the truck battery draining.
The truck sat for about the same amount of time as last time and I went to start it today. I put the key into the ignition and it started. No problem at all. Amazing that the glove box light was the problem all along.
Thanks again guys. Your the best!
Brook is offline   Reply With Quote
Old 09-10-2008, 06:14 PM   #23
no problem glad that the guys of this forum could help you out so don't be afraid to ask question even the dumb ones we all get like that sometimes
Old 09-17-2008, 07:02 PM   #24
1982gmc is on a distinguished road
Dead Battery Problem Solved!!!!
Hey I am back and I would like to give you all THANKS, for the advice on my dead battery issue.I found out the battery was good the starter was also good "BUT" although the alternater was charging when I unhooked the battery.I thought it kept the truck running it must be ok...WRONG...I finally took the Alternater to get checked and the positive diode was bad,and they have pos and neg diodes.The positive diode puts a constant drain on the battery when it goes bad,so DEAD GOES THE BATTERY.Took it to repair shop it cost $15.00 and it works like new...PROBLEM SOLVED.Thanks again to all and take care.
1982gmc is outta here
1982gmc is offline   Reply With Quote
Old 09-18-2008, 08:30 PM   #25
can't be right al the time i guess i will have to remeber about the pos and neg just incase i run ito the same problem thanks for lettin us know what was going on
Old 09-20-2008, 07:59 AM   #26
rdhack's Avatar
rdhack has a spectacular aura aboutrdhack has a spectacular aura aboutrdhack has a spectacular aura about
An easy and inexpensive way to check your battery and for a short circuit drain is simply to unhook your battery the next time you know your truck is not going to be used for an extended period of time ...say 2 weeks.
If after that time period you hook your battery back up......if its starts your battery is most likely good and you have a short somewhere that is draining it.
If after that time period you hook your battery back up and it does not start then you knw its simply the battery has gone bad.
If its a short and hard to find.....leave your battery unhooked while your truck is not in use and it will always be ready after hooking it back up. I had to do this with a former vehicle one time in the past....never did find that battery drain.
Good Luck!
MY first truck was a FORD.......I've owned Chevy's ever since.
1995 K2500 4x4 5.7L Cheyenne
1991 T-10 Blazer 4.3L Tahoe Package
2000 Ford Taurus - Spouses
rdhack is offline   Reply With Quote
Tags
battery
2003 Sierra Battery Dead... breaks42 GMC Truck Forum 2 07-08-2008 07:00 AM
new battery duckkiller0010 Chevy Truck Forum 14 08-11-2007 10:34 AM
Battery Problem chuck01 Chevy Truck Forum 3 07-03-2006 05:46 AM
Bad alternator or battery? xanarchistx GMC Truck Forum 6 06-14-2006 08:36 PM
battery problem 72'CaminoKid Chevy Truck Forum 11 05-26-2006 03:33 PM
