Old 08-16-2008, 03:11 PM   #1
Brook is on a distinguished road
Dead Battery
Last time I was here you guys were great. You solved the starter problem in no time flat. I thanked you before and I'll thank you again for the help.
So now I'm back in some need of help. First off I have a 1989CK PU. Had it for years. Had the engine rebuilt, new starter,water pump,plug wires,sensors, battery. Before I replaced the starter the battery was going dead. When I replaced the starter you guys said to check the ground. Checked the ground and it seemed ok. Ran the truck for 2 months. No problems.
Now the truck sat for 2 weeks and the battery was dead. Went out and charged it and it started and ran for a while. My question is what would drain the battery in a 2 week span and how would I find the source.
Thanks,
Brook
Brook is offline   Reply With Quote
Old 08-16-2008, 03:23 PM   #2
junior3382's Avatar
if there is a ground that is not connected properly you could have a constant draw in power therefore leading to a dead batt... but you mentioned that before the starter issue the batt was dying... how old is it? Did you replace it last time?
Old 08-16-2008, 03:31 PM   #3
junior3382-
The battery is 2 mo old same as the starter.
Old 08-16-2008, 03:33 PM   #4
junior3382's Avatar
See, I did not know that.... you mentioned the ground on the starter is fine.... What about the main ground from the motor to the frame? Or the ground wire that runs from the neg terminal to the frame?
Old 08-16-2008, 03:42 PM   #5
The grounds seem great. No frayed wires, corrosion or rust the contact area seems good. Is there anything else I should look for?
Old 08-16-2008, 03:50 PM   #6
junior3382's Avatar
With the key off and out of the truck there is a test you can do. If you have a multi-meter, while there is no appearent usage of the DC power, test the batt. If everything is off, there will be no draw off the batt, however, if the multi-meter is showing a draw of power, then there is a bad connection or perhaps something on that should not be. So before we tear apart your truck, test this out and see if there IS a draw. Then we may be able to trace it and repair it. Now if there is no draw then the batt might just be a dud. therefore I would return it under warranty isses.
Old 08-16-2008, 04:57 PM   #7
I would look around for something small drawing power, ie. the glove box light!, low speed fan. Something from the run side of the ignition switch which is not shutting down
Old 08-16-2008, 05:44 PM   #8
Thanks for both sugesstions. I'm going to check out both and I'll get back to you.
Very much appreciate it,
Brook
Old 08-17-2008, 06:14 AM   #9
All good suggestions but the first thing I would do is check that your alternator is charging. Also a faulty alt. can cause a battery drain.
Old 08-17-2008, 09:14 AM   #10
heavychevy85's Avatar
heavychevy85 has a spectacular aura aboutheavychevy85 has a spectacular aura about
i had similar case of this so here is some steps to take
1.unhook the leads off the batt. put on trickle fo a day or so it might be dead dead were jumping and running won't bring it back fully
2. test ur alternater see if its pushing any juice out to the batt while truck is running
3. start ur truck let run 10-15 min while truck is still running unhook ur pos. lead off batt. if truck is still running the alternater is still good(it won't run all day like this just a little bit) if the truck shuts off as soon as u unhook the pos. lead then its prolly a faulty alt.
so try these step don't have to be in order but this should find the problem have fun
heavychevy85 is offline   Reply With Quote
Tags
battery
2003 Sierra Battery Dead... breaks42 GMC Truck Forum 2 07-08-2008 07:00 AM
new battery duckkiller0010 Chevy Truck Forum 14 08-11-2007 10:34 AM
Battery Problem chuck01 Chevy Truck Forum 3 07-03-2006 05:46 AM
Bad alternator or battery? xanarchistx GMC Truck Forum 6 06-14-2006 08:36 PM
battery problem 72'CaminoKid Chevy Truck Forum 11 05-26-2006 03:33 PM
