Old 08-23-2008, 12:08 PM   #1
rcrick0 is on a distinguished road
NO start
Hi all
i have a 2000 chevy s-10 v-6 it wont start unless you put starting fluid in it, has good pressure up to the motor, has new pump, filter, new injectors kit, computer, is there a sensor that tells the injector to spray gas besides the computer , someone told me there one in distributor that fires the injectors , the book doesnt say nothing on it , is it true any help would be good , thamks
Rick D.
rcrick0 is offline   Reply With Quote
Old 08-23-2008, 12:49 PM   #2
Your problem could be a weak spark or a defective temperature sensor. Have you checked it for error codes?
Case 7230 is online now   Reply With Quote
Old 08-23-2008, 01:15 PM   #3
spark is good
no codes , it did give a code a while back on coolant temp sensor but does not gve a code for it now
Old 08-23-2008, 03:37 PM   #4
brad4eva's Avatar
brad4eva will become famous soon enoughbrad4eva will become famous soon enough
would deff change cololant temp sensor could possibly be it, If the ECM reads it as no TEMP it won't start because it would think its getting hott
//B-rad
brad4eva is offline   Reply With Quote
Old 08-23-2008, 05:09 PM   #5
ok, thanks you guys for help on it ill put new one in
Old 08-23-2008, 06:37 PM   #6
brad4eva's Avatar
Alrighty man, MAKE sure you contact us back and tell us whats rollin'
//B-rad
Old 08-25-2008, 06:12 PM   #7
with any no start condition check for spark, check for gas at plugs then go from there.
Old 10-08-2008, 05:38 AM   #8
replaced it (coolant temp sensor) still nothing, yes has spark, will start and run if you spray gas in throttle body will idle till you stop spaying fuel..
Old 10-08-2008, 06:42 AM   #9
put it on a scanner, sounds like something is weak but not setting a code, did you replace the sensor for the ecm not the guage one?
Old 10-08-2008, 08:29 AM   #10
RoadHammerTLM has a spectacular aura aboutRoadHammerTLM has a spectacular aura about
This may sound dumb but I have had this happen 4 or 5 times over the years. And that is the ignition switch. The contacts may have come out of adjustment and it will allow it to turn over but not start. I have had this happen in a Chevy, Ford, and a Dodge of all different years models. It may be worth the check.
Hammer
RoadHammerTLM is offline   Reply With Quote
Will not start hoppe GMC Truck Forum 4 06-15-2008 09:23 PM
No start!! amzsprmn GMC Truck Forum 2 05-05-2008 07:41 PM
Oh no. Now it won't start. Brook Chevy Truck Forum 7 05-02-2008 06:53 PM
Won't Start 53flatty GMC Truck Forum 2 02-26-2007 05:29 PM
Ram won't start 85s10383 Dodge Truck Forum 2 07-25-2005 08:55 PM
