Old 08-25-2008, 06:31 PM   #1
jedi3622 is on a distinguished road
Need Transmission advice
Hi this is my first post. I need some help, I just bought a 97 1500 with 5.7 and 4l60e 4WD. The transmission was bad. I have removed it and was in the process of trying to find a new one, well new to me but used, and to find out that in my area they are a highly sought item. My question is without having to tear the trans apart to change the output shaft, is there any other transmission that i can use like a blazer trans or a tahoe trans or any other year that will work woth the electronics inside the trans. Any ideas will help!!!!! Thanks tons in advance.
jedi3622 is offline   Reply With Quote
Old 08-25-2008, 07:08 PM   #2
heavychevy85's Avatar
heavychevy85 has a spectacular aura aboutheavychevy85 has a spectacular aura about
i don't know personaly but i'm sure some of these senior members can help ya out so just hold on be patient and i was wondering what area are you from
heavychevy85 is offline   Reply With Quote
Old 08-25-2008, 07:09 PM   #3
Hey I see you are from muncy I am from Towanda. Of course you probably haven't heard of it noone ever has. I am North of scranton about an hour close to the NY state line.
Old 08-25-2008, 07:20 PM   #4
z07
z07's Avatar
The entire 700r4 lineage is plagued by the 3-4 clutch pack failures. Buying a used one will only put a little bit of time on the clock. But if you get it rebuilt by someone who knows them they can address the known issues with better than stock parts at cheaper than dealer prices.
Old 08-25-2008, 07:59 PM   #5
Banned
were getting alot of guys from pa n here. lol welcome to the club
Old 08-25-2008, 09:03 PM   #6
brad4eva's Avatar
brad4eva will become famous soon enoughbrad4eva will become famous soon enough
Yeah! no fair im from tn no one here from tn but me!! and also DO NOT BUY A USED 4L60E get it rebuilt YOU will regret it if you don't
//B-rad
brad4eva is offline   Reply With Quote
Old 08-26-2008, 12:42 AM   #7
I agree get the 4l60e rebuilt it's cheaper in the long run this time have (THE BEAST) Sun shell put on this trans along with HD parts it will last longer.
Old 08-26-2008, 06:08 AM   #8
PAPA BEAR's Avatar
PAPA BEAR has a spectacular aura aboutPAPA BEAR has a spectacular aura aboutPAPA BEAR has a spectacular aura about
i agree with zO7 and Gmc a beast and other up grades make for a better transmission
PAPA BEAR is offline   Reply With Quote
Old 08-26-2008, 10:58 AM   #9
Well a rebuilt is still an option but not for at least a few weeks maybe even a month or two or even three. I would really like to get it up and running just so I can have it. Some of the u pull it yards up here only charge 50-75 per trans so if I could throw a used one at it till I can afford to purchase a rebuilt one I will. And also is the 4L80E a heavier duty trans versus the 4L60E and is it a direct swap?
Old 08-26-2008, 11:38 AM   #10
Is it an 80E direct swap for a 60E????
In a word, no. While they will bolt up with minimal modifications, the small modifications do not make this a real good solution. Since this is an electronic transmission, your controller will not only not plug in, it will not control the 80E trans.
While you are at the salvage yard, you may check to see what the real cost of this transmission will run. I find it hard to believe that a 4L60E, or 80E can sell for 50 bucks.
Core charges are far greater than this. Heak, if you could buy them for this price, you should buy every one you could get your hands on. You can sell them as cores for far more money.
These are expensive transmissions, and sell for more money than you think.
Around my area, even a core Th350 or 400 brings more money than 50 bucks.
You will also want to make sure you get the correct transmission for the right engine.
LS"X" engines use a different bellhousing than the earlier gen engines. Truth is that they will bolt up except for one bolt, but thetorque converters are metric for the later LS engines, and this will not bolt up.
This can be an easy repair, but could get ugly in a hurry. Save your time and money, and do it right the first time.
Balancing that transfer case and trans is not a fun job, and doing it over and over agin just does not sound appealing to me.
I would never install a used transmission in anything for the above reasons.
Doing it right the first time is a time and money saver in the long run.
Tags
3-4 clutch, 4l60e, tranny, transmission
Okay, here we go, any advice? ikos10 Mazda Truck Forum 3 06-09-2007 05:22 AM
Ok, need advice.... anyone.... ikos10 Chevy Truck Forum 8 03-16-2007 03:32 AM
I need some advice NateDog07 Ford Truck Forum 9 01-05-2006 09:01 AM
Looking for some advice LoneWolf General Truck Forum 17 09-23-2005 02:28 PM
I need some advice jaclinto Truck News (headlines) 0 05-02-2005 09:16 AM
