Old 08-27-2008, 07:55 PM   #1
Hayden's Avatar
99 1500 caliper sticking
Took my brothers truck to tow my camper up north and the front driver caliper stuck after a few minutes and a few miles down the road. I replaced the caliper (dual piston caliper $65) and it still does it. I was told the rubber line might me cracked or peeled on the inside but havent replaced that yet.. Has anyone had this problem before. Just the drivers side does it so it kinda rules out the master cylinder. could it be the porportioning valve also?
Old 08-27-2008, 09:34 PM   #2
nah, it's the rubber line.
i'd rather be hunting
Old 08-27-2008, 10:37 PM   #3
hotrodpc's Avatar
Yes sir. Its the rubber line. Of all my years working on vehicles never seen anything so strange, but I had the same issue just 2 weeks ago on my 80 GMC and that is what it was. Funny thing was, the line appeared to be in good shape. But I guess the inners tear apart, fluid will go one way, but will not let it back up working like a one way valve. Replace the line, problem solved. I have a thread posted about it, something titled 80 GMC Brake ....
Old 08-28-2008, 01:41 AM   #4
Yes I have heard it happening in fact I have two new one's for my truck im just needing to put them on.
Old 08-28-2008, 06:52 AM   #5
rubber line like everyone else.
Old 08-28-2008, 10:38 AM   #6
When you replaced the caliper did you flush the line? Brake fluid gets like molasses over time, you need to bleed it till the fluid is clear and the pedal go down easy (if its a manual bleed with another person). If this is the case then flush all the lines.
Old 08-29-2008, 01:42 PM   #7
Hayden's Avatar
Thanks for the replies. I havent had a chance to work on it yet but do have the line since that is what I thought the problem was. I just wanted some of your opinions on the matter. I'll let you all know what the outcome was. Thanks
Old 08-29-2008, 02:40 PM   #8
rdhack's Avatar
rdhack has a spectacular aura aboutrdhack has a spectacular aura aboutrdhack has a spectacular aura about
Always replace the line first...its the cheapest, then the caliper if needed.
MY first truck was a FORD.......I've owned Chevy's ever since.
1995 K2500 4x4 5.7L Cheyenne
1991 T-10 Blazer 4.3L Tahoe Package
2000 Ford Taurus - Spouses
rdhack is offline   Reply With Quote
Old 08-29-2008, 02:40 PM   #9
rdhack's Avatar
OH and go ahead and do both sides if you are keeping this truck for a while.
Old 08-31-2008, 02:18 PM   #10
Hayden's Avatar
It was the line. Works good now. Thanks all
Tags
brake hose, brakes, caliper
Caliper not releasing rayjavu Chevy Truck Forum 12 04-25-2008 05:22 AM
2003 s-10 blazer caliper removal mudseeker Chevy Truck Forum 8 02-07-2007 08:11 PM
Gas pedal sticking closed bodean Chevy Truck Forum 3 09-20-2006 08:54 PM
90' 1500 Should I buy? 92Jag Chevy Truck Forum 6 01-29-2006 10:06 PM
Have a problem with bugs sticking to your radiator? bubbas91lariat Ford Truck Forum 4 01-03-2006 01:49 PM
