| Oil pressure i was driving my truck for the first time in a while on the road atleast i just put a bunch of new parts on it and wanted to see how it rode well any way i got about two miles down the road and my oil pressure gauge droped to around 20psi when coasting and the same when sitting still the motor runs great the oil is at full cuz i just changed it about two months ago. the only thing i can see were there is oil leaking from is the oil pan gasket and the front and rear seal that goes with it so any help will be appreciated |
| Okay, in addition to the PM we just exchanged, if there is a small oil leak.. then odds are the oil pressure dropped because the oil level dropped. But like I said, those gauges do move around quite a bit...
| throw some lucas in it and forget about it. what's the pressure at when under load?
| it use to be at 40 and went to 50 ish then dropped to 20 and goses to 40 ish |
| i do need to replace my oil pan gaskets |
| mine jumps around too, but you mentioned that it is not running right either which indicates to me there is other issues
| would pure water in the motor make it run retarded when starting |
| oh when i got to my destination and went to start the truck up well at first it didn't want to start by just hittin the switch i had to hold it to the floor i might have to bump my idle up a little i don't know i always had to do that to my derby cars when i was smashen them when it stalled i held my foot to the floor and cranked the key |
| um... YES... IF you mean in the oil....LOL... and do not expect to go very far! LOL... but as for the coolant, not really this time of year, but you are going to wanna get that out before winter or you will freeze the block...
| Is this carbed? Like I said before, are you getting gas or water in the oil?
| Too much pressure! | dawright_1988 | Chevy Truck Forum | 20 | 03-22-2008 11:48 PM |
| oil pressure | jacquesje83 | GMC Truck Forum | 4 | 12-24-2007 07:26 PM |
| Oil Pressure | waterloo88chev | Chevy Truck Forum | 3 | 07-16-2007 11:39 PM |
| 91 2.8 oil pressure | rlarryg | Chevy Truck Forum | 0 | 12-05-2006 10:50 AM |
| Tire Pressure? | Walleyes4me | Chevy Truck Forum | 2 | 08-03-2005 01:53 PM |
