Old 09-07-2008, 08:55 PM   #1
austinpowers is on a distinguished road
vacuum prob
i need help with brakes. the other day this just started happening and i cant figure it out. i hit the brakes and they are real stiff and make like a hissing noise, and the truck idle will go down real bad and almost stall out. this only happens when i hit the brakes. when it is sitting idle it runs fine and it drives fine. i hit the brakes at a dead stop and it bogs down real bad and sometimes even stalls. im pretty sure its a vacuum prob i checked the rubber hose going to the booster and it looked ok and it was getting suction. i replaced the master cylinder and bleeded the brakes really good and it still didnt fix the problem. would a bad brake booster cause this to happen. any thoughts will help thanks.
96chevyw/t15004x2
austinpowers is offline   Reply With Quote
Old 09-07-2008, 08:59 PM   #2
Welcome
Sounds like you are on the right track! take the hose off the booster plug it step on the brake and if ther is no problem you found it!
Old 09-07-2008, 09:19 PM   #3
what he said, sounds like a bad booster.
i'd rather be hunting
Old 09-07-2008, 09:22 PM   #4
ok it sounds good i will try that out tomorrow. thanks
96chevyw/t15004x2
Old 09-07-2008, 10:27 PM   #5
To check the vacuum booster, pump the brake pedal with the engine off until you've bled off all the vacuum from the unit. Then hold the pedal down and start the engine. You should feel the pedal depress slightly as engine vacuum enters the booster and pulls on the diaphragm. No change? Then check the vacuum hose connection and engine vacuum. If the hose is alright, the problem is in the booster and the booster needs to be replaced.
Pretty simple little test.
Did the booster take on any brake fluid by any chance?
Often times the master can leak fluid into the booster, and the fluid will ruin the diaghram. I think the guys are correct, and you have a bad booster.
Old 09-08-2008, 07:17 AM   #6
Jessie is on a distinguished road
Make sure the filter on the booster vaccum hose isn't clogged.
Jessie is offline   Reply With Quote
Rear end prob/ swap Faster4344 Chevy Truck Forum 6 06-20-2008 09:56 PM
1994 GMC Sierra 4X4, EGR prob., battery drains trunkmonkey Chevy Truck Forum 5 04-01-2008 06:15 PM
blazer brake indicator light prob pbouffard Chevy Truck Forum 12 11-08-2007 07:40 PM
GMC Canyon 2005 SLE / Crew Cab Brake prob bassplayer60 GMC Truck Forum 3 11-07-2006 06:00 PM
1991 manule trani prob will not go in reverse I3 U T L 3 R Chevy Truck Forum 2 09-28-2005 04:25 AM
