| 1997 2500 with 5.7 Oil Pressure Issue 1997 2500 with 5.7 150,000 miles. After motor is warm my oil pressure is dropping to 10 psi or less at idle with truck in gear and my Check Engine Light comes on. If I shift to neutral the RPM goes up about 150 more RPM’s and the oil pressure goes to about 10 psi and the light goes out. When running the oil pressure is pretty solid at 40 to 45 psi. I have put a mechanical oil pressure gauge on to verify the accuracy of the electronic gauge and it validated that the low pressure is real. The mechanical gauge would sweep up and down as expected and showed 40 to 45 psi as well. Any thoughts to what it may be? Oil pump screen clogged? Needs new pump? Engine is tired? Can I remove the oil pan and change the pump without lifting the engine or removing steering components? |
| you may be able to do it by lifting it a little bit but i dont think you can unless you do. i would run some seafoam through it and see if it just has a clogged passage. but to me it sounds like your pump is on the fritz. i would change it before it turns real bad |
| I`ll check my service manual when i get home tonight and get gmS SPECS |
| to be sure,, i would put a mechanical gauge on it before you replace the pump. ive seen those idiot gauges malfunction,or get out of calibration. i hate to see you go throught an oil pump if you dont need it. |
| oh sorry .. i forgot you did put a mechanical gauge on it.. its been a long day....its most likely the pump. |
| hopefully its just a pressure relief stuck on the pump and not a cam bearing sgtarting to turn.
| my dang truck won't start..1997 Gas Dodge Ram 2500 4x4 | jjg84 | Dodge Truck Forum | 6 | 02-29-2008 03:42 AM |
| transmission leaking fluid 1997 dodge ram 2500 4 x 4..HELP!! | jjg84 | Dodge Truck Forum | 3 | 07-24-2007 08:52 PM |
| 1997 Dodge 2500 4X4 Diesel Brakes | Dan Tinch | Dodge Truck Forum | 1 | 03-15-2007 05:16 PM |
| 1997 Chevy Silverado 2500 Turbo Diesel | Big Diesel | Chevy Truck Forum | 2 | 11-10-2005 10:25 AM |
