| | #11 |
| Full Member Join Date: May 2007
| The trouble code is coming up a 12 which does not display anything |
| | #12 |
| I Changed the TPS and MAP and neither fixed it ): |
| | #13 |
| Do you think the timing can be off? Can you check your timing without a timing light? |
| | #14 | |
| Senior Member Join Date: Oct 2008 Location: south BAMA
the 12 code it means when the key is on and the engine not runing that all your electronic are ok but your most of your tranny codes will not read that way but you might can try a tranny shop if the guys are nice the can put there code reader on it and see what comes up im saying that b/c most places down here check it for free
__________________ **IF YOU AIN'T FIRST YOUR LAST** SHAKE AND BAKE !!!!!!!! ![]() | |
| | #15 | |
but most shade tree machanics can do it by ear ive done it before and got it really close
| | #16 |
| i did not think a MAP sensor would fix it. a malfunctioning TPS would have a high idle and late shift points. code 12 would indicate everything is ok but you might have checked it when it was not flashing a code. have you checked the cap and rotor?? |
| | #17 |
| now when you say it surges do you mean that the motor kinda jumps for just a sec and then shifts ?
| | #18 |
| It is a 5spd so when you change into 3rd for example the truck surges (loses power) I am sure it is a timing issue at this point... How do you adjust the timing? |
| | #19 |
| when its running you turn the destibuter one way or the other just a little bit at a time and on your harmonic balance pully there is a mark should be one the timing cover when the #1piston hits the it should match the mark on there you can see it real good with the timing light
| | #20 |
| if you go buy a timing light most times there is a step buy step on there
| Speed Channel Truck Stop: Todd Bodine Takes an RC Break (Speed TV) | trucknews | Truck News (headlines) | 0 | 09-01-2005 09:30 AM |
| USA Truck Second-Quarter Profit Surges (AP via Yahoo! Finance) | trucknews | Truck News (headlines) | 0 | 07-14-2005 11:30 AM |
| Skinner surges to truck pole at California (USA Today) | trucknews | Truck News (headlines) | 0 | 02-25-2005 07:30 PM |
| Relive the 2004 Craftsman Truck and Busch Series on SPEED (Speed TV) | trucknews | Truck News (headlines) | 0 | 12-15-2004 03:30 PM |
| Turnpike To Increase Truck Speed Limit (Cleveland - NewsNet5 via Yahoo! News) | trucknews | Truck News (headlines) | 0 | 08-12-2004 05:30 PM |
