| Junior Member Join Date: Oct 2008 Location: northeast ohio
| u-joints I have a 2003 silverado ext cab had to change u-joint on back shaft now i have a shake at 30-35mph any idea,s on what it may be and how to fix it,,,,thanks |
| Are you sure that the new u joint is lined up correctly in the pinch bolts? other then that the drive line is balanced and you may have rotated it 180 degrees? |
| did you press the joint with a press? if you did it with a hammer in a vise you probably bent the shaft. You have to be very careful with the new aluminum driveshafts
| Senior Member Join Date: Oct 2008 Location: south BAMA
| man i hate changin factory u joints on chevys they have that teflon junk in there and its a pain if you dont have heat to put on it
__________________ **IF YOU AIN'T FIRST YOUR LAST** SHAKE AND BAKE !!!!!!!! ![]() |
| U-Joints I agree with you I bought this tool that it has different sizes of adapters so that you have a choice to use it on different cars/trucks in fact I haven't even used it but it's there when I need it oh one uses an impact to press them out it's a lot easier. |
| Please verify that the shaft is till in "phase". Even one spline off will throw the shaft out of balance. If it is a one piece shaft and phase cant be messed up, then make sure that the slip yoke is lubed properly. Even automatic transmissions require a little grease on the splines. |
| Totally forgot,...make sure that you have not overtightened the u-joints. Too tight and the bearing becomes a bushing, and this is not very good. |
| Senior Member Join Date: Aug 2008 Location: Kentucky
| my experience has always been another u-joint but these guys know a lot more than i do..little s10- had all the u-joints replaced in it at least 2 times for all 3 and 1 time for one of them if there is a grease fitting make sure to keep them greased..that helps a lot also
__________________ looks are cosmetic.....its whats under the hood that counts ![]() ![]() |
| Senior Member Join Date: Oct 2008 Location: west kentucky
| just took the back u joint out of my truck it had the shakes and the skweaks did have supervision mine fell into pieces on removel wasent that bad but pressing it back in the yolk and linning it back up was very important i was told.no more vibration or skweaks good luck |
| ball joints | heavychevy85 | GMC Truck Forum | 5 | 09-21-2008 05:33 PM |
| U-joints | lonestar1128 | Chevy Truck Forum | 12 | 08-28-2008 09:33 AM |
| Rubber ball joints/ bushings | Ninja_Lawn_Guy | GMC Truck Forum | 3 | 08-14-2008 09:03 AM |
| question about ball joints on 98 explorer | 72'CaminoKid | Ford Truck Forum | 3 | 12-13-2007 03:46 PM |
| f350 ball joints | bristlehead | Ford Truck Forum | 3 | 09-17-2006 11:13 AM |
