Old 10-11-2008, 10:50 PM   #1
barbermike34 will become famous soon enoughbarbermike34 will become famous soon enough
94 no cruise control
94 silverado where is the cruise control located mine is not working need to know what to check
barbermike34 is offline   Reply With Quote
Old 10-11-2008, 10:52 PM   #2
junior3382's Avatar
There are a couple places. One is in the relay, another is on the TBI itself and then there is the multifunction switch. How does it not work though? Sparatic, or simply not at all? Did you check fuses for one that might be blown? If it is the multi switch, do your blinkers, high beams and wipers work?
Old 10-11-2008, 10:54 PM   #3
93blazer's Avatar
93blazer has a spectacular aura about93blazer has a spectacular aura about
i would start with maybee fuses or start at the throttle body there should be two cables on the side of the throttle body one for the gas peddle and one for the cruise ,follow it from the throttle body and it will go straight to the cruise controll box
**IF YOU AIN'T FIRST YOUR LAST**
SHAKE AND BAKE !!!!!!!!
93blazer is offline   Reply With Quote
Old 10-11-2008, 10:55 PM   #4
every thing works perfect except the cruise
Old 10-11-2008, 10:55 PM   #5
FaselZ71's Avatar
On the TBI there's 2 throttle cables one goes to gas pedal obviously the other goes to the firewall over by the master cylinder theres alittle black box and I believe it say like cruise control module on it. That's where it is on my 92. Have you check the fuse because I believe there is a fuse under the dash. As far as troubleshooting the module I don't know my cruise control doesn't work either but I'm not to conerned about it. Hope this helps good luck man!
Old 10-11-2008, 10:58 PM   #6
would there be a fuse just for the cruise
Old 10-11-2008, 10:59 PM   #7
FaselZ71's Avatar
I think so... I honestly believe it's labeled cruise I'll go check real fast
Old 10-11-2008, 10:59 PM   #8
junior3382's Avatar
in the fuse panel below the dash. When you remove the cover, ON the cover will be a diagram of what all the fuse are
Old 10-11-2008, 11:02 PM   #9
i hope that is all it is and if it is i am gonna fell like a dumb butt for not checking that first
Old 10-11-2008, 11:05 PM   #10
FaselZ71's Avatar
I stand corrected I just looked at my truck and there's no cruise control fuse that I could find in the fuse box but the little black box say Electro-Motor-Cruise-Control and it right there on the fire wall next to the master cylinder.
Cruise control help woody367 GMC Truck Forum 13 09-09-2008 11:29 PM
Sensitive cruise control RASwift GMC Truck Forum 5 05-08-2008 11:41 PM
Cruise control troubleshooting rubberhead Chevy Truck Forum 6 08-13-2007 09:52 PM
cruise control vanhal Chevy Truck Forum 3 12-19-2006 06:09 PM
cruise control vanhal Chevy Truck Forum 1 02-11-2006 11:52 PM
