Old 10-20-2008, 03:50 PM   #1
D-Man is on a distinguished road
My dome lights are stuck ON!!
I've removed my dimmer switch, door pins, stereo and alarm trigger but still the light's are ON.. By removing the fuse for the "Courtesy Lamps" then all goes dark.
Is there something I'm missing here? I know it's a constant "Hot" circuit that's turned on by a ground switch (door pins) or am I wrong? A wiring schematic would be GREAT but finding a decent one is next to impossible.
Sorry...This is a 94 extended cab Chevy truck.
D-Man is offline   Reply With Quote
Old 10-20-2008, 05:24 PM   #2
76silverado's Avatar
76silverado has a spectacular aura about76silverado has a spectacular aura about
Yeah a door pin might be stuck, they are easy to see. After that I would check your ground and make sure you didn't accidently turn them on with the switch for the headlights.
http://s513.photobucket.com/albums/t...t=HPIM1105.jpg
'76 Silverado10 Custom Deluxe, 350 4barrel, th350 auto FULL TIME FOUR WHEEL!
76silverado is offline   Reply With Quote
Old 10-21-2008, 06:11 AM   #3
cburcham73 has a spectacular aura aboutcburcham73 has a spectacular aura about
check the light itself. you could have the ground wire touching the metal and making the circuit.i think your right about them using the ground to switch on the light from the door.
cburcham73 is offline   Reply With Quote
Old 10-21-2008, 08:35 AM   #4
What do you mean? What ground? Even with the headlights, door pins, dimmer switch, alarm, etc. unplugged the lights are still ON.
I'm open to all suggestions or ideas!! This one's got me pretty irritated!!
Thanks.
Old 10-21-2008, 09:56 AM   #5
Banned
if you rotate the dimmer switch past a certaint point it will turn your interior lights on... it will click into place... ussually althe way twards bright
Old 10-21-2008, 09:57 AM   #6
if you have unplugged everything,then check the light itself. your problem could be there............
Old 10-21-2008, 10:01 AM   #7
do you have a switch on the dome light? [on the dome cover?]
Old 10-21-2008, 10:03 AM   #8
Banned
sure it isnt ona timmer or something... it takes a good 30 sec for mine to shut off if i dont lock the doors... that is the only way i remember to sometimes
Old 10-21-2008, 11:23 AM   #9
I'll definitely check them out!! All of them. Dome and both under dash lights.
There's two separate lights with switches/buttons on either side of the dome light. Both work independently of the dome light and both still work perfectly.
This is a '94 model truck. No timer for the courtesy lights.
Old 10-21-2008, 02:43 PM   #10
I had some of my pin switches go bad even the glove box has one remember and I bought mine at the dealership there dirt cheap I replaced all of mine why you ask because it drained my battery one night by the light staying on.
Chevy Dome Light/ Steering Wheel Squeaking CarolinaChevy Off-Topic 3 07-03-2008 12:30 PM
Dome Lights Nugget Hunter Ford Truck Forum 4 06-16-2008 12:06 PM
dome lights jktuck GMC Truck Forum 2 04-27-2007 09:49 AM
lost running lights and dome came on? DonEllis Chevy Truck Forum 9 04-14-2007 02:40 PM
Dome light not working correctly mochester Toyota Truck Forum 1 05-28-2006 12:18 AM
