| Junior Member Join Date: Oct 2008
| The brake lights and rear signals work on my 96 Silverado until the headlamp switch is turned on and then no brake lights or tail lamps work but the rear turn signals do with a fast blinking. Reverse lamps work until the headlamp switch is on. All fuses are good and I just changed out both tail lamp circuit boards. Any ideas on the problem and solution??? Thanks |
| the toggle switch in the dash was the problem I had |
| Do I have to remove the dash/ instrument panel to change the toggle/light switch? |
| mines a 93 and just a few torques screws around the instrument cluster gives you access |
| If your have trailer wiring at the rear check for corrosion or shorts....
| | #7 | |
Good tip here too!
__________________ John Wayne 2000 F-350 7.3L Powerstroke 4x4 | |
| I have changed the headlight switch and both taillamp circuit boards and the problem still exist. Now on to searching for rusted grounds and shorts. Thanks for the help! |
| 99 Silverado fog lamps | rockitman | Chevy Truck Forum | 10 | 10-14-2008 10:17 AM |
| Brake Light Stays On - 98 Silverado | Hamneggs | Chevy Truck Forum | 9 | 08-02-2008 04:01 PM |
| '97 Silverado -brake signal wire for trailer brake controller | mcZEd38 | Chevy Truck Forum | 6 | 05-17-2008 06:51 PM |
| 88 silverado dash brake light | joecuccovia | Chevy Truck Forum | 6 | 03-02-2008 04:21 AM |
| 98 Silverado Trailer Brake Control | rimfire | Chevy Truck Forum | 4 | 02-06-2008 11:06 PM |
