Old 11-01-2008, 04:13 PM   #1
Thirdeye is on a distinguished road
Exclamation Acceleration Hesistation
Hi everyone,
I have a 1989 c/k1500 4x4 truck, 4.3 L, 5 speed. The truck really seems to be stumbling bad while accelerating. IF you feather the throttle though, it doesn't seem to do it. It just started doing this today and the last time I was driving it the SES light came on. I had something similar happen to me earlier and it turned out that the rotor contact was carboned up bad. I had an dist cap and rotor kicking around, so i cleaned it up and put them on and it worked fine. It's dark out now, so I'm going to check that possibility out tomorrow in the daylight. Is there anything else that you think it could be? I'd like to retrieve the code it's giving me. Can I jump the computer data link using some hairpins or paper clips or something so it will flash me the code?
Thirdeye is offline   Reply With Quote
Old 11-01-2008, 04:24 PM   #2
go to auto zone for a freebe.. if it does not help a good scan would help
Old 11-01-2008, 04:26 PM   #3
no autozone up in these parts
Old 11-01-2008, 04:26 PM   #4
Kennyray's Avatar
Kennyray will become famous soon enoughKennyray will become famous soon enough
While its dark out you might want take a spray bottle and mist your spark plug wires. If you see a light show that could be your problem.
Kennyray is offline   Reply With Quote
Old 11-01-2008, 04:29 PM   #5
well i don't know where these parts are so see if someone will scan it for a reasonable price
Old 11-01-2008, 04:32 PM   #6
I have a good set of wires that I'm going to put on anyways tomorrow.
Old 11-01-2008, 09:25 PM   #7
rdhack's Avatar
rdhack will become famous soon enough
I had that problem on my S-10 and rotor, distributor cured it.
MY first truck was a FORD.......I've owned Chevy's ever since.
1995 K2500 4x4 5.7L Cheyenne
1991 T-10 Blazer 4.3L Tahoe Package
1998 Oldsmobile Bravada 4.3L Vortec Smart Drive
rdhack is offline   Reply With Quote
Old 11-02-2008, 05:44 AM   #8
Your truck is OBD1 so you should be able to pull codes with the paperclip no problem. Do a search of this forum for instructions. You can also go to www.troublecodes.net for what the codes mean. Good luck.
Old 11-02-2008, 07:46 AM   #9
i just have to put the clips in and the turn the ignition to on do i not?
Old 11-02-2008, 08:18 AM   #10
76silverado's Avatar
76silverado has a spectacular aura about76silverado has a spectacular aura about
Originally Posted by gjm View Post
In my Haynes manual it states, to read the OBD-1 codes without the scan tool / OBD-1 reader, use a short jumper wire and jump the two terminals. A=ground and B= diagnostic test terminal. On my 1994 GMC the data link is located under the steering wheel, under the dash. The ground is the top right and the diagnostic second from right. After jumping the two, turn key to on, DO NOT START. The service engine soon light will flash. Trouble code 12 will flash three times. One flash, pause, two flashes. This happens three times, then if there are any other codes, it will flash them. On my truck it flashed five times, pause, four times. The code was 54. It did this three times. Then back to 12, then 54 again. I read the code in the manual. It said, fuel pump relay low voltage, check the fuel pump relay and circuit for shorts or damage. Of course I changed the relay and it didn't fix my problem. Is this wildly known? This is the first I have heard of this. Any experiences or comments of how to use this to get the maximum info??
Thats how ya do it.
http://s513.photobucket.com/albums/t...t=HPIM1105.jpg
'76 Silverado10 Custom Deluxe, 350 4barrel, th350 auto FULL TIME FOUR WHEEL!
76silverado is offline   Reply With Quote
slow acceleration dj79 Chevy Truck Forum 7 04-26-2007 08:36 PM
rough acceleration eaclark GMC Truck Forum 7 04-11-2007 09:40 AM
slow acceleration still dj79 Chevy Truck Forum 3 03-26-2007 01:46 PM
rough idle and acceleration... 1bj Nissan Truck Forum 4 01-20-2007 09:54 PM
acceleration problem ekellner Chevy Truck Forum 2 12-17-2004 09:51 AM
