Old 11-02-2008, 10:20 AM   #1
redneck 0991 is on a distinguished road
89 k1500
every time i lock my truck in 4x4 there is a strange poping noise and hops a little even in a straight line. in 2wd it is just fine, no poping or hop. i had to replace the rear end when i bought the truck cause there was a 5 in hole in the rear differential. the gears were the same in the 4x4 as my 93 2wd so i made the swap( the code in my glove box was GU6 in both trucks). i'm wondering if maybe i have a cv axel goin bad or maybe it is just one of my auto lockers goin bad. any suggestions are appriciated.
redneck 0991 is offline   Reply With Quote
Old 11-02-2008, 10:54 AM   #2
pull the front driveshaft and make sure the spline is lubed. if it gets dry it will bind
Old 11-02-2008, 04:53 PM   #3
Moderator
i am assuming that you looked at the glovebox code knowing that the rearends that it has are the same ones that came from the factory. always best to check the diff rather than a code on older model stuff. i dont think cv joints are going to make your tire hop like that. been wrong before but dont see that as a possibility.
Old 11-02-2008, 06:35 PM   #4
i haven't checked the front diff, the feller i bought the truck from said that everything is all the same as the day he bought it new. but i haven't thought that the old geezer might have lied just so that he could just get the truck out of his hair. i remember that the rear end that i swaped into it is after market too, but there wasn't a tag on the rear diff when i pulled it giving the gear ratio. so can i check the ratio without busting the pumkin open and actually counting the teeth on the ring gear itself. and where will the ratio be posted on the front diff.
Old 11-03-2008, 06:48 AM   #5
Moderator
should be a tag mounted somewhere. some people can jack up a wheel and count the revolutions on the tire with the single turn of the driveshaft. to me, it isnt very accurate but i guess it can get you close. crackin a diff is not hard and sometimes might be a good idea since the fluid might want to be changed.
Old 11-03-2008, 06:05 PM   #6
i just put new fluid in the diff when i stabbed that rear end in the truck. i will try jackin up the truck and see what results i get, might be a few days before i get back with the results
need some help or info 92 k1500 sport Chevy Truck Forum 3 01-12-2008 11:11 PM
92 k1500 sport Chevy Truck Forum 5 06-26-2007 02:45 PM
97 K1500 won't start Bairplayer Chevy Truck Forum 10 04-07-2007 07:22 PM
I would like some help with my 93 K1500 flathead52 Chevy Truck Forum 6 03-04-2007 08:25 PM
96' K1500 350 V8 Charles1221 Chevy Truck Forum 3 11-07-2006 06:28 PM
