Old 11-02-2008, 05:05 PM   #1
1994chevtruck is on a distinguished road
ignition timing prolems
ok so i just bought a 1988 chevy 4x4, new trans and the motor has been replaced, i cant say that the motor is new but it was replaced, it has absolutly no power at all, when i first drove it it ran like a scaled dog but it idled fast, was hard to start and had detination issues. so i checked the timing and at idle it was around 25 to 30 before tdc. but when you reved it, it went to around 15 or so. we ill unpluged the wire so the computer didnt mess with the timing so i could check base timing and it was at 12! so i backed it off to 0 like its suppose to be, turned the truck off, pluged the wire back in and now it idles fine, easy start, no detination, but has no power, when i rev it up now the timing goes to 4-6 after tdc and idles at 4-6 before tdc, i unpluged the knock sensor thinking that it could be giving a faulty single and messing with the timing and it stayed the same. what could i check to try to figure out why the timing is all messed up.
thanks in advance
chadd
1994chevtruck is offline   Reply With Quote
Old 11-02-2008, 05:31 PM   #2
Welcome to the forum............base timming should be set at 4-6 degrees with the wire unhooked
Old 11-02-2008, 05:50 PM   #3
but y would the timing be going after top dead center when on throttle
Old 11-02-2008, 05:52 PM   #4
The timing changes with the change of rpm. its doing what it should
Old 11-02-2008, 05:56 PM   #5
i thought the timing is suppose to go further away from before tdc. that is what my 94 does and it runs like a champ. this one startes firing after tdc
Old 11-02-2008, 07:25 PM   #6
stumpuller454's Avatar
stumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud of
i`ve seen worn out distributor gears do wonky things....
Red seal certified Journeyman Automotive Mechanic
Supercharger comming soon!
stumpuller454 is online now   Reply With Quote
Old 11-02-2008, 08:26 PM   #7
Kennyray's Avatar
Kennyray will become famous soon enoughKennyray will become famous soon enough
could also be worn or stuck centrifigal plates in the distributor.
Kennyray is offline   Reply With Quote
Old 11-02-2008, 08:30 PM   #8
so it would just be best to buy a whole brand new distributor and be done with it huh
Old 11-02-2008, 08:35 PM   #9
Kennyray's Avatar
should be able to pick up new one ones with new bushing and springs. they used to sell them with a variety of spring so that you could custom tune your advance. NAPA should carry them not sure of the discount auto parts stores.
Old 11-02-2008, 09:42 PM   #10
wradman is on a distinguished road
i'd start with checking the plugs see how they are burning then do a compresion check
wradman is offline   Reply With Quote
1995 Silverado ignition timing Mark Chevy Truck Forum 4 09-14-2008 04:12 PM
timing sudduths1 Dodge Truck Forum 0 06-08-2008 09:21 AM
454 bad timing? travis1475 Chevy Truck Forum 1 06-01-2008 06:36 PM
2.2 timing mazdaman Mazda Truck Forum 2 02-15-2007 05:33 PM
GMC Timing mbarcher GMC Truck Forum 6 06-14-2006 06:29 PM
