Old 11-03-2008, 04:33 PM   #1
sigpros is on a distinguished road
99 7.4 running lean
I have a 99 with the 7.4. The check engine light keeps going on and off. when it's on the mpg goes down. When i check it says "running lean on the left bank" I have had it to the dealer twice. New fuel filter,pump, intake gaskets and a tune up. Still same problem. Also when I drive it stop and turn it off then start it again it doesn't want to run you can stand on the gas and it won't go over 15mph. after about a minute it will just take off and run fine. I also think it is doggy compared to the chevy 350's I have owned. first bb. Thanks for any help
sigpros is offline   Reply With Quote
Old 11-03-2008, 05:27 PM   #2
76silverado's Avatar
76silverado has a spectacular aura about76silverado has a spectacular aura about
It could be an O2 sensor or bad cat. Welcome to the forum you will find us nice and helpful.
http://s513.photobucket.com/albums/t...t=HPIM1105.jpg
'76 Silverado10 Custom Deluxe, 350 4barrel, th350 auto FULL TIME FOUR WHEEL!
76silverado is offline   Reply With Quote
Old 11-03-2008, 08:54 PM   #3
JOHN JAY will become famous soon enoughJOHN JAY will become famous soon enough
tell the dealer they failed to correct the problem. the sensors are putting into limp mode. I would clean them ,the cat wouldnt be the first thing I would suspect intermitant. I hate it when the dealer tip toe around with your money...
JOHN JAY is offline   Reply With Quote
Old 11-04-2008, 07:53 AM   #4
By sensors do you mean the O2 sensors?
Old 11-04-2008, 10:50 AM   #5
Could be gummed injector/s. Have you tried running a can or two of fuel injector cleaner thru it? I have had good results with both Lucas and Cyclo.
Old 11-04-2008, 11:19 AM   #6
you paid someone good money to fix it! take it back and make them do it right, and don't give them anymore money they quoted you a price to fix it and for what you paid it should be right
Old 11-04-2008, 05:07 PM   #7
I was going to fix it myself. I will try the fuel injector cleaner. the dealr said it wasn't getting fuel to the injectors. Also I read on a diffenent post that after market O2 sensors are junk. What do you guys think about that?
Old 11-04-2008, 05:10 PM   #8
If the dealer said it wasn't getting fuel to the injectors and the problem is still there ask why he charged you for all the wrong work! I'm sorry but if it was charged I'd be putting a hold on the credit card for unsatisfactory work
Old 11-04-2008, 07:12 PM   #9
stumpuller454's Avatar
Which codes are comming up, just the p0171?
IF so inspect
-exhaust leaks
-fuel filter restriction
-vacuum leaks after the MAF sensor (hoses, connections, throttle body, intake, and EGR)
-is your idle high or unsteady? > inpect IAC operation
-check PCV operation
-If you have the california AIR system, it could be stuck OPEN
-contaminates in fuel
-VCM connections ( make sure are tight and connected, grounds good)
seing that you are also experiencing power loss, and that it appears the dealer went over the fuel and ignition side of things....and they must have done the intake stuff to try and get rid of a vacuum leak, but you could varify your intake vacuum at an idle, should be around 17-19"hg (inches of mercury) maybe check your air filter, maybe they missed it? and get the exhaust checked for restriction or a leak. you should ask the dealer if they did an injector balence check aswell...>stump
Old 11-05-2008, 05:04 PM   #10
The intake gaskets were shot. they were leaking antifreeze out. I can hear an exhaust leak. I will climb under there and try to track it down. I did the fuel pump myself because they wanted $700.00 to do it.
2001 2500HD 6.0L 4x4 Power Issue - Lean Fuel nicholwa Chevy Truck Forum 5 10-28-2009 06:49 AM
Need advice. 89 Suburban has slight lean to right. ponie1992 GMC Truck Forum 4 06-14-2008 08:09 AM
1999 Silverado "Banks too Lean" chucky6965 Chevy Truck Forum 5 02-10-2008 07:17 PM
'90 G20 5.7L Running Bad Kingcool Chevy Truck Forum 2 01-31-2008 03:15 PM
Lean to the Left, Lean to the Right (New York Times) trucknews Truck News (headlines) 0 12-06-2004 11:30 AM
