Old 11-09-2008, 03:38 PM   #1
LC4short is on a distinguished road
Abs light
I just replaced my front wheel hub assemblies with two brand new ones. And now my ABS light won't go off. Any suggestions........
LC4short is offline   Reply With Quote
Old 11-09-2008, 03:44 PM   #2
stumpuller454's Avatar
whcih vehicle you workin on? were the hubs replaced for bearing problems? make sure everythings connected, to verify a signal from the sensors unplug them and connect a voltmeter on two wires in the plug and spin your hub and see if it generates a voltage....
can tell you more if we know what vehicle/make/model/year that sorta stuff (:
Old 11-09-2008, 03:52 PM   #3
Hello Thanks for the reply. The thruck is a 2001 Silverado extra cab with a 4.8.2wd. Yes the front bearing hubs were bad, but I had no lights prior to replacing them. I know It's not the module since it has been replaced within the last six months.
Old 11-09-2008, 05:02 PM   #4
MORROWMUDDER's Avatar
MORROWMUDDER will become famous soon enoughMORROWMUDDER will become famous soon enough
possible ya could of got some grease or some sort of debris in it to cause the sensor to not be able to sense what is going on. just a thought
MORROWMUDDER is offline   Reply With Quote
Old 11-09-2008, 09:15 PM   #5
are you sure the plugs are connected all the way and you did not bend a pin?
Old 11-09-2008, 09:33 PM   #6
computer may just need to complete a few drive cycles to clear the code.
if it stays on for a day or so then you will need to take it to a shop to have the code read.
i'd rather be hunting
Old 11-12-2008, 07:14 AM   #7
Banned
bigz has a spectacular aura aboutbigz has a spectacular aura about
make sure when you put the hub assembly on everything is good and tight... a bad vibration will cause that light to come on
bigz is offline   Reply With Quote
Tags
abs, abs light
ABS & Red brake light both on???? crazyhorse357 Chevy Truck Forum 6 09-14-2008 04:17 PM
serves light bob975 Chevy Truck Forum 4 05-11-2008 06:24 PM
ABS light fisher429 Dodge Truck Forum 1 09-17-2006 01:14 AM
abs light rustbucket Chevy Truck Forum 3 08-13-2006 02:10 PM
Check Engine light and overdrive light on chief Introductions 0 02-05-2006 08:12 AM
