Old 11-17-2008, 04:49 AM   #1
truckabuser is on a distinguished road
4wd wont' stay engaged
1996 z71 4wd. transfercase with floor pull...
discovered the otherday my 4wd wasn't working. needed to go forward/backward quite a few times before it would engage.
when it was 1/2 engaged, it would make a ratcheting sound, when the rear wheels were spinning and the front were not engaged, turning, but not matching speeds..when front and rear axles turned and turned until they matched speeds, ching ching ching ching ching ching....CLUNK and it's in gear fully. like the dog gears are hittng and spinning, then finally locking....then go forward, alright, as soon as i go in reverse, go back into forward, lost drive to the front axle again... wtf?
i've gone through 3 acutators. think something is tore up inside the axle?
don't they make a good heavy duty actuator that snaps into place quickly and firmly? or one that doesn't overheat and fry itself?
truckabuser is offline   Reply With Quote
Old 11-17-2008, 06:09 AM   #2
they make a manual system...4x4 Posi-Lok - 4WD Engagement Systems ...are you sure you are buying the correct actuator? I found on my 92 there were 3 different one that fit. Mine needed the heavy duty, which was a little bigger diameter, but the smaller ones worked, for a while. I also put a switch on the floor mount, I found the roller switch on the tranny would act up and not always engage. (just a rocker switch w/light)
Old 11-17-2008, 10:44 AM   #3
hmmmm, so in theory, i could engage the transfer case but not the axle, so i could have low range to the rear axle only? might be worth my efforts.....
but then again, could i have damage inside from the acutator engaging 1/2 time?
i'd hate to buy all this new stuff and have it fix nothing if something else is tore up.
Old 11-17-2008, 03:47 PM   #4
Drain the lube out of the front axle and see whats in it!
Tags
4wd
92 Chevy s-10 Dosent want to stay running bonzikodey Chevy Truck Forum 8 07-17-2008 01:27 PM
83 gmc not wanting to stay running well cold joeydeherrera54 GMC Truck Forum 2 04-13-2007 06:46 AM
Truck will start but wont stay running PickUpGirl787 Chevy Truck Forum 6 12-29-2006 11:08 AM
Truck loses breaks when I engaged 4wd? dayved Chevy Truck Forum 2 12-10-2005 03:57 PM
