Old 11-24-2008, 01:53 PM   #1
snakeone is on a distinguished road
help with 4 wheel drive not locking in
i have a 89 chevy scottsdale 4x4 truck and i replaced the actuater because it was blowing fuses and now it wont lock in any ideas
snakeone is offline   Reply With Quote
Old 11-24-2008, 02:52 PM   #2
rdhack's Avatar
rdhack has a spectacular aura aboutrdhack has a spectacular aura aboutrdhack has a spectacular aura about
Check your connections
MY first truck was a FORD.......I've owned Chevy's ever since.
1995 K2500 4x4 5.7L Cheyenne
1991 T-10 Blazer 4.3L Tahoe Package
2000 Ford Taurus - Spouses
rdhack is offline   Reply With Quote
Old 11-24-2008, 03:02 PM   #3
stumpuller454's Avatar
somebody was mentioning earlier about different actuators? somthing about their length or something...
so it doesn`t blow fuses now?
SUPERCHARGED 454 K2500 GMC!
Watch My Youtube Videos!!<<<
Old 11-24-2008, 03:24 PM   #4
welcome to the forum
check the power Thru the transfer case and out to the thermal resister. You may have had a shorted wire and when you disturbed it it quit blowing fuses
Old 11-24-2008, 05:06 PM   #5
when i replaced the actuater it had bear wire that was touching the hog head , so i installed new actuater it was the same type and size and now it wont blow the fuse but it not gettin power to actuater now
Old 11-24-2008, 05:11 PM   #6
then it may be the switch in the transfer case, its a switch with a ball on the end. try bypassing it and see if you get power
Old 11-24-2008, 05:13 PM   #7
ok there 3 wires that go in the top side of the hoghead and they have power goin in but none coming out . i was thinking bout tryin to but a switch on it with a light but the wires on actuater are the same color and not sure which would be the hot wire
Old 11-24-2008, 05:14 PM   #8
purplehavoc is on a distinguished road
Like mentioned,see if you have power at the switch on the t-case.
I repaired an 89 chevy that had the same problem,but the blower motor would stop working when the 4x4 quit as well.
Found they are on the same CKT and one of the wires had rubbed through shorting to ground at times.
purplehavoc is offline   Reply With Quote
Old 11-24-2008, 05:29 PM   #9
is it possible to run it off of a switch i saw that somewhere earlier and if so how?
Old 11-24-2008, 07:22 PM   #10
put a switch across the wires that lead to the switch on the top of the transfer case
Can I 4-wheel drive? celinaman060 Chevy Truck Forum 17 11-23-2009 01:28 PM
2 wheel drive to 4 wheel conversion frank3ks 4x4 trucks / off road 6 03-31-2008 09:30 PM
Wheel Question on my 4 wheel drive??????????????? 92BlueZ71 Chevy Truck Forum 4 03-19-2007 04:06 PM
4 Wheel Drive Help? 97Z71 Chevy Truck Forum 5 03-04-2007 07:32 PM
4 wheel drive 92BlueZ71 Chevy Truck Forum 1 03-06-2006 10:37 AM
